8.75 spool #1348089
12/08/12 07:34 PM
12/08/12 07:34 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Does anyone make a thrust block so I can stay with the adjustble axle bearings?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: 8.75 spool [Re: HOTMOPR] #1348090
12/08/12 07:53 PM
12/08/12 07:53 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Actually I just blew apart my open diff and took the block out.. Should work I think. Only thing I wonder is there will not be a center cross pin so the block could spin. I wouldnt think it matters..
Re: 8.75 spool [Re: HOTMOPR] #1348091
12/08/12 08:09 PM
12/08/12 08:09 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i had the exact question for the same reason. what i ended up doing was wacking off a piece of 727 output shaft as it seemed to fit nicely in the 30 spline spool. then i surface ground the ends to make sure they were parallel. haven't tried it yet but should work fine. i didn't want something floating around in there and though there are no splines in the center of the (strange) spool i'm pretty sure there's just enough to keep the piece i made from turning. honestly i don't think it's an issue either way there's only going to be about .010" of play in there.
