Re: 88 magnum roller lifter camshaft
[Re: basscat]
#1348010
12/08/12 09:16 PM
12/08/12 09:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
An 88 isn't a magnum, that's important for valve train considerations.
What is it you want?
If you wish to keep the rollers there are a number of cams out there. If you want to convert it back to flat tappet there are lots more to choose from.
[Re: basscat]
#1348014
12/09/12 12:18 AM
12/09/12 12:18 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
send your cam to www.bulletcams.comuse the HR259/326 on the intake, HR266/325 on the exhaust http://www.bulletcams.com/Masters/HRlobes.htmreuse the lifters if in good shape, check to see if the pushrods will work...if they're a tad short due to the base circle reduction, maybe mill the heads .040 to use them, or measure and find the right length.
[Re: basscat]
#1348015
12/09/12 01:40 AM
12/09/12 01:40 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
I'm not wanting to change much, just wanted a little bump. I was told to keep the rollers if possible. Any sugestions where to lokk to match this engine with a small street cam?
Summit, jegs. Ebay
[Re: 76dodgeboy]
#1348016
12/09/12 02:50 AM
12/09/12 02:50 AM
Posts: 15,487 Florida
scratchnfotraction
the hughes whiplash is a nice street cam in the roller cam 318s I run a lunati voodoo roller cam with comp 901-16 springs all stock roller gear. good daily driver cam. done a few of the flat tappet whiplash cams and 1 roller whiplash. they just sound down right nasty at idle,smotths out by 1500 rpm, goes right in a stock low comp smog engine and makes a nice street cruzer. I did not change anything on the 2 flat tappet cams,just stuck them in the stock 318 with a spring change,added a carb/headers.
[Re: basscat]
#1348018
12/09/12 01:17 PM
12/09/12 01:17 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Yep. You will need the older style non-roller pushrods too.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
