A body brakes #1347721
12/08/12 07:32 AM
12/08/12 07:32 AM
TX
RiskyRickey Offline OP
TX
I have a 74 duster whih disk brakes.I also have a 70 duster with drum brakes.What do have i have to change with the spindles.Thanks in advance
Re: A body brakes [Re: RiskyRickey] #1347722
12/08/12 09:04 AM
12/08/12 09:04 AM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
not sure of question
Re: A body brakes [Re: TheRamMan] #1347723
12/08/12 09:11 AM
12/08/12 09:11 AM
TX
TX
Need to know what i have to change to get the disk on the 70
Re: A body brakes [Re: RiskyRickey] #1347724
12/08/12 09:13 AM
12/08/12 09:13 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
If you want to put the 74 stuff on it, spindles and UCAs because of the bigger ball joint for sure. Not sure what else, if anything.
Re: A body brakes [Re: moparguy7074] #1347725
12/08/12 09:52 AM
12/08/12 09:52 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Also if you currently have a front sway bar on the 70 you will need to rear mount the calipers to clear the bracket.
Re: A body brakes [Re: RiskyRickey] #1347726
12/08/12 09:57 AM
12/08/12 09:57 AM
TheRamMan Offline
TheRamMan  Offline
transfer everything
Re: A body brakes [Re: TheRamMan] #1347727
12/08/12 10:08 AM
12/08/12 10:08 AM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: A body brakes [Re: RiskyRickey] #1347728
12/08/12 12:26 PM
12/08/12 12:26 PM
UCA/spindle & everything from the spindle outward. LCA is the same. The assy's are interchangeable from side to side but you want to keep the original orientation with the calipers on the opposite side of the spindle as the hose/hard line frame tab is (so the hose goes under/across the inside of the spindle to reach the tab) unless as said a sway bar makes you reverse that. rebuilt calipers are cheap/reliable & 76 (only) A body calipers have a larger (2.75") bore than 73-75 A body calipers (2.6") for more front bias which is always needed (& priced the same). I would get some Ceramic pads & consider doing a bed in procedure (google it). If a longer hose is ever needed ask for 78 volare hoses & cut off HALF of the metal bracket on the middle of the hose
Re: A body brakes [Re: RapidRobert] #1347729
12/08/12 07:14 PM
12/08/12 07:14 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I vote that you swap all the 74s brakes and K-Frame to the 70
