Re: Suspension, what's next? need help
[Re: SpareParts]
#1347705
12/08/12 06:32 PM
12/08/12 06:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Shackle angle is fine, made sure I paid attention to that. Cal tracs will not be seen on this car for as long as I can avoid it. They make things easier but I'd rather do the homework and keep it spring only. Less is more approach is kinda what the car goes by.
Keep the front segments as stiff as possible.. take the clamps off the rear segments... that'll give you as much rotation as possible... then its up to the shocks to control the lift... then IF needed you can add clamps on the rear(but I doubt it) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1347706
12/08/12 08:10 PM
12/08/12 08:10 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
one other item in that Afco article was the relationship of the spring surface to the spring seats. If there is any difference side to side (camber) that really messes with spring rate.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: MikeyT]
#1347708
12/08/12 08:53 PM
12/08/12 08:53 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
mikeQuote:
Boy< ain't that the truth!
Lol, ^^^^ this guys seen the car in action. Did I surprise ya Mikey? ![](/ubbthreads/images/graemlins/laugh.gif)
[Re: Cab_Burge]
#1347713
12/09/12 10:56 AM
12/09/12 10:56 AM
Posts: 118 Ms.
Dartwizer
Ms.
Put a Good set of true leaf springs and Good double adj.shocks, and go have some fun....
What are a "good set of leaf springs" I had my best luck with a A body using a BB with Ma Mopars 002/003 leafs, street and strip
I used the 002/003 leafs myself,had good luck with them.They wore out,put a new set of 002/003.Not so good,maybe the vendor is different now.Had Gregg Luneak at Tri City Launcher make me a set for my 70 Dart. Cheap,no.But they work for me.
[Re: moparguy7074]
#1347716
12/09/12 11:19 AM
12/09/12 11:19 AM
MR_P_BODY
What about a pinion snubber? Is one required with the ss springs to achieve maximum body lift?
A pinion snubber was a bandaid on stock wornout springs... if the spring is doing the job properly it will give lift.... I believe the rear clamps are most of his problem due to the fronts trying to lift but as it does the rear is trying to pull it back down so it ends up as a wash in his case ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MikeyT]
#1347720
12/09/12 03:51 PM
12/09/12 03:51 PM
SpareParts
Janesville, WI
I had my best luck with CalTracs and mono leafs. It feels a lot firmer when leaving than the SS springs did. I thought the 002/003 springs were for a 2800 LB car
Ted, I keep telling the kid, that, but he doesn't believe me! He insists on doing stuff the hard way! ![](/ubbthreads/images/graemlins/laugh2.gif)
PS. I do respect him for it too. Mike
If I liked easy I'd have an LS1 camaro with half the money in it and go a second faster ![](/ubbthreads/images/graemlins/stirthepot.gif)
