Re: Suspension, what's next? need help [Re: SpareParts] #1347705
12/08/12 06:32 PM
12/08/12 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Shackle angle is fine, made sure I paid attention to that. Cal tracs will not be seen on this car for as long as I can avoid it. They make things easier but I'd rather do the homework and keep it spring only. Less is more approach is kinda what the car goes by.
Keep the front segments as stiff as possible.. take the
clamps off the rear segments... that'll give you as
much rotation as possible... then its up to the shocks
to control the lift... then IF needed you can add
clamps on the rear(but I doubt it)
Re: Suspension, what's next? need help [Re: MR_P_BODY] #1347706
12/08/12 08:10 PM
12/08/12 08:10 PM
gregsdart Offline
gregsdart  Offline
one other item in that Afco article was the relationship of the spring surface to the spring seats. If there is any difference side to side (camber) that really messes with spring rate.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Suspension, what's next? need help [Re: SpareParts] #1347707
12/08/12 08:15 PM
12/08/12 08:15 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
mike
Boy< ain't that the truth!
1969 Dodge Dart Swinger
Re: Suspension, what's next? need help [Re: MikeyT] #1347708
12/08/12 08:53 PM
12/08/12 08:53 PM
Janesville, WI
SpareParts Offline OP
Janesville, WI
mike
Lol, ^^^^ this guys seen the car in action. Did I surprise ya Mikey?
Re: Suspension, what's next? need help [Re: SpareParts] #1347709
12/09/12 12:41 AM
12/09/12 12:41 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
mike
Oh yes! Goes better then most, and looks awesome too!
Mike
Re: Suspension, what's next? need help [Re: MikeyT] #1347710
12/09/12 01:02 AM
12/09/12 01:02 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Put a Good set of true leaf springs and Good double adj.shocks, and go have some fun....
Re: Suspension, what's next? need help [Re: Dartwizer] #1347711
12/09/12 04:05 AM
12/09/12 04:05 AM
What are a "good set of leaf springs" I had my best luck with a A body using a BB with Ma Mopars 002/003 leafs, street and strip
Re: Suspension, what's next? need help [Re: Cab_Burge] #1347712
12/09/12 10:04 AM
12/09/12 10:04 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
What about a pinion snubber? Is one required with the ss springs to achieve maximum body lift?
Re: Suspension, what's next? need help [Re: Cab_Burge] #1347713
12/09/12 10:56 AM
12/09/12 10:56 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
I used the 002/003 leafs myself,had good luck with them.They wore out,put a new set of 002/003.Not so good,maybe the vendor is different now.Had Gregg Luneak at Tri City Launcher make me a set for my 70 Dart. Cheap,no.But they work for me.
Re: Suspension, what's next? need help [Re: Dartwizer] #1347714
12/09/12 11:11 AM
12/09/12 11:11 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Here is pic of the springs,Mopar left ,Tri City right
Re: Suspension, what's next? need help [Re: Dartwizer] #1347715
12/09/12 11:16 AM
12/09/12 11:16 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Mopar bottom,Tri city top
Re: Suspension, what's next? need help [Re: moparguy7074] #1347716
12/09/12 11:19 AM
12/09/12 11:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A pinion snubber was a bandaid on stock wornout springs...
if the spring is doing the job properly it will give
lift.... I believe the rear clamps are most of his
problem due to the fronts trying to lift but as it
does the rear is trying to pull it back down so it
ends up as a wash in his case
Re: Suspension, what's next? need help [Re: MR_P_BODY] #1347717
12/09/12 02:10 PM
12/09/12 02:10 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I had my best luck with CalTracs and mono leafs. It feels a lot firmer when leaving than the SS springs did. I thought the 002/003 springs were for a 2800 LB car
Re: Suspension, what's next? need help [Re: babarracuda] #1347718
12/09/12 02:37 PM
12/09/12 02:37 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Ted, I keep telling the kid, that, but he doesn't believe me! He insists on doing stuff the hard way!
PS. I do respect him for it too.
Mike
Re: Suspension, what's next? need help [Re: MikeyT] #1347719
12/09/12 03:47 PM
12/09/12 03:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mike
I hear ya on this one and I too tried to do the most w/the least till I woke up and stepped up to a bolt in suspension that surpasses most.............
Re: Suspension, what's next? need help [Re: MikeyT] #1347720
12/09/12 03:51 PM
12/09/12 03:51 PM
Janesville, WI
Janesville, WI
Mike
If I liked easy I'd have an LS1 camaro with half the money in it and go a second faster
