70 CUDA door latches #1347269
12/07/12 08:12 AM
12/07/12 08:12 AM
NY
moparmatt0 Offline OP
NY
Does any body rebuild the door latches for a 70 cuda or have new ones.
Re: 70 CUDA door latches [Re: moparmatt0] #1347270
12/07/12 10:21 AM
12/07/12 10:21 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
By rebuild, do you mean replate/refinish; or are yours cracked/worn out at the pivots/latches? Replating them correctly is expensive and you have to disassemble and reassemble them yourself.
Re: 70 CUDA door latches [Re: jbc426] #1347271
12/07/12 10:38 AM
12/07/12 10:38 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Jules rebuilds door latches.
Re: 70 CUDA door latches [Re: burdar] #1347272
12/07/12 11:44 AM
12/07/12 11:44 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Even better! Give Jules the Wiperman a call. He does world class work.
Re: 70 CUDA door latches [Re: burdar] #1347273
12/07/12 12:13 PM
12/07/12 12:13 PM
NY
NY
How do you get in touch with jules?
Re: 70 CUDA door latches [Re: moparmatt0] #1347274
12/07/12 12:16 PM
12/07/12 12:16 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Re: 70 CUDA door latches [Re: jbc426] #1347275
12/07/12 01:06 PM
12/07/12 01:06 PM
NY
NY
Thanks I looked at the website but I did not see a phone number.
Re: 70 CUDA door latches [Re: moparmatt0] #1347276
12/07/12 01:16 PM
12/07/12 01:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
He's on here...send him a PM.
Re: 70 CUDA door latches [Re: burdar] #1347277
12/07/12 04:29 PM
12/07/12 04:29 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
450-656-5438
Re: 70 CUDA door latches [Re: JulesdaWiperman] #1347278
12/08/12 08:18 PM
12/08/12 08:18 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
70 is different than 71-74...so rebuilding is the best option
Re: 70 CUDA door latches [Re: AARCONV] #1347279
12/09/12 10:26 AM
12/09/12 10:26 AM
NY
NY
What is the difference because I think I need to replace mine?
Re: 70 CUDA door latches [Re: moparmatt0] #1347280
12/09/12 12:05 PM
12/09/12 12:05 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
you know how on a 71-4 you can lock the door with the knob and then close the door and it's locked..like all the modern cars now...on the 70..when you push down on the knob,close the door and the knob lifts back up..you can only lock the door with the key....70 only....my left latch has a worn out groove where it contacts the striker and the door rattles there...I might weld it up and grind that part down for a tight fit when it wraps the striker..other than that, I have not taken it out to see what the physical difference is between the two..swap meets have them all bunched in a box and you need to know what you are looking at...but mine is a minor fix...
Re: 70 CUDA door latches [Re: AARCONV] #1347281
12/09/12 11:52 PM
12/09/12 11:52 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Re: 70 CUDA door latches [Re: screamindriver] #1347282
12/10/12 08:13 AM
12/10/12 08:13 AM
NY
NY
Thanks for the help I am going to look for 2 good used ones mine are not in the best shape
