Shift fork ??? #1346891
12/06/12 01:27 PM
12/06/12 01:27 PM
Overpriced Housing Central
RobX4406 Offline OP
RobX4406  Offline OP
I pulled a 4 speed apart that was having issues going into 2nd gear. This is the 1-2 fork, which I've never seen in the few stock 833 I've torn down.
All the one I've seen look like this from Brewers site.
Might that smaller fork be part of the issue with the trans not wanting to go into second gear?
Re: Shift fork ??? [Re: RobX4406] #1346892
12/06/12 01:30 PM
12/06/12 01:30 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I've seen those in earlier 4-spds, '64-5 or so.
Re: Shift fork ??? [Re: 446acuda] #1346893
12/06/12 02:30 PM
12/06/12 02:30 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Yes it can be part of the problem. They were only used for a short time.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Shift fork ??? [Re: 64dodge572] #1346894
12/06/12 03:14 PM
12/06/12 03:14 PM
RobX4406 Offline OP
RobX4406  Offline OP
I think I'll suggest buying a long arm fork and fresh synchro rings. One ring was broken and this apparently is the second time it's happened.
Re: Shift fork ??? [Re: RobX4406] #1346895
12/06/12 04:01 PM
12/06/12 04:01 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You are better off with the later steel forks used with the ratchet side cover.Just cut of the extension that engages the ratchet and you're good to go.
Re: Shift fork ??? [Re: 62maxwgn] #1346896
12/06/12 04:23 PM
12/06/12 04:23 PM
works good, last a long time
Re: Shift fork ??? [Re: Cab_Burge] #1346897
12/07/12 12:58 AM
12/07/12 12:58 AM
RobX4406 Offline OP
RobX4406  Offline OP
Not my transmission, doing it on a budget.
Thanks for the input regarding the cover and forks.
Re: Shift fork ??? [Re: RobX4406] #1346898
12/07/12 03:41 AM
12/07/12 03:41 AM
Check with your local dodge dealer, you may be suprised on how cheap they are on some parts Don't forgget that you need to remove the little knub for it to work in aearlier trans, I broke a stock brass one at the races back in the day and I manged to beg a spare from one of the factory racers at a test and tune for Mopars only just before the Wintenationals back in the day when I raced a 4 speed car I borrow a file and filed around the knub and broke it off with a pair of vice grips plyers The steel fork are way better than the brass ones where
