Page 2 of 5 1 2 3 4 5
Re: Low Deck 400 Combos.... [Re: old yeller] #1346797
12/08/12 09:08 PM
12/08/12 09:08 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Are we just talking about factory Low decks?
lets hear that combo bird..what makes the bird fly
Re: Low Deck 400 Combos.... [Re: earthmover] #1346798
12/08/12 11:46 PM
12/08/12 11:46 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
451 - Stock 440 crank, Stage VI heads, Mopar 590 cam, 13:1 compression, Indy 440-3, Quick Fuel 1050. 3300 lbs at the line, 6.25/110 1/8 9.86/135 1/4
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Low Deck 400 Combos.... [Re: earthmover] #1346799
12/09/12 02:10 AM
12/09/12 02:10 AM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
Jack Daniels on the rocks!!..lol
Re: Low Deck 400 Combos.... [Re: old yeller] #1346800
12/09/12 12:53 PM
12/09/12 12:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No, that`s what makes YOU fly................
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346801
12/09/12 01:02 PM
12/09/12 01:02 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My old DartSport now owned by 73DartSport, pump gas 451" low deck(just a 440 crank in a 400 block), half filled, 590 purpleshaft MP cam, CNC ported Eddy heads, 2" headers, M1 tunnel ram, 2 750 Quickfuel carbs, 1.6 Harland Sharp rockers, 6.20's and 9.80's at 3050 total pounds with driver. Most fun and reliable(and streetable) combo I've ever ran.
Edit: I mentioned half fill in the block but I may be wrong, I dont think this 451 had any block filler. The purple 69 Dart had a 500" low deck that was half filled. Aluminum main caps on both motors.
Re: Low Deck 400 Combos.... [Re: ProSport] #1346802
12/09/12 01:50 PM
12/09/12 01:50 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
i run a low deck in my dart
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Low Deck 400 Combos.... [Re: 440Jim] #1346803
12/09/12 06:43 PM
12/09/12 06:43 PM
charlotte nc
jimmysarrow Offline
jimmysarrow  Offline
charlotte nc
When building a 511 w/ 4.25 crank , can you run aluminum rods without a lot of grinding on the block or better to run steel rods?
Re: Low Deck 400 Combos.... [Re: jimmysarrow] #1346804
12/09/12 09:06 PM
12/09/12 09:06 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have K1 rods in my car
Re: Low Deck 400 Combos.... [Re: 440Jim] #1346805
12/09/12 09:25 PM
12/09/12 09:25 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Who else here is running a Low Deck 400 combo?
Never been on a dyno, but it's run 6.80's in my 3200 pound Dart,
Mine has not been on the dyno either, but it has run 5.75 in my 3250 lb Dart. More typical weather 5.85 1/8, 9.28 1/4
400 block, 4.375" bore
4.250" Callies crankshaft, 511 CID
6.535" H-beam rods, 2.2" (Chevy) rod journals
13.5 CR
Comp Cams MM305S solid lifter, flat tappet cam 279/287 at 0.050", .650"/.630" lift (published)
Indy 440-1 heads, milled to 68cc, some porting
Indy 400-3 intake, single four, 4500 pattern
2-1/8" x 32" headers
Block filled to 2.6" from the deck
Aluminum main caps
440 jim just curious what rear gear r u running in that car?And what r u trapping at?Not meanig to high jack....
Re: Low Deck 400 Combos.... [Re: bigtimeauto] #1346806
12/10/12 01:40 PM
12/10/12 01:40 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Me too.
Re: Low Deck 400 Combos.... [Re: bigtimeauto] #1346807
12/10/12 02:23 PM
12/10/12 02:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a low deck in my Barracuda...Even a shorter deck in my other one
Re: Low Deck 400 Combos.... [Re: Al_Alguire] #1346808
12/10/12 02:57 PM
12/10/12 02:57 PM
iowa
badplymouth67 Offline
iowa
68 Dart low deck indy sr max wedge ports indy intake 4.15 eagle crank eagle rods ross pistons 12.5 to 1 640 solid 1050 quick fuel on alcohol best of 9.01 at 147
Re: Low Deck 400 Combos.... [Re: badplymouth67] #1346809
12/10/12 03:07 PM
12/10/12 03:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Some minor details. 525" Low deck, B1MC heads, Bullet roller, CP Pistons 15.2-1 GRP rods, Callies crank, cast unported intake, Gary Williams Dominator, made 1050 on the dyno.
Re: Low Deck 400 Combos.... [Re: Al_Alguire] #1346810
12/10/12 04:03 PM
12/10/12 04:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
Would that low deck block be of the aluminum KB variety
Re: Low Deck 400 Combos.... [Re: Cab_Burge] #1346811
12/10/12 04:25 PM
12/10/12 04:25 PM
Plant city fl
70Dart499 Offline OP
Plant city fl
Another question for you guys, say I wanted to replace the 906 heads on my 499 with some better flowing aluminum heads, what would be the best choice without buying different headers, pistons or rocker arms? Thanks!
1970 Dart Drag Car
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346812
12/10/12 04:30 PM
12/10/12 04:30 PM
CNC ported Eddy RPM
Re: Low Deck 400 Combos.... [Re: Cab_Burge] #1346813
12/10/12 04:49 PM
12/10/12 04:49 PM
Plant city fl
Plant city fl
CNC ported Eddy RPM
Don't the Eddy RPM's require different pistons and/or headers because of the angled spark plugs??
1970 Dart Drag Car
Re: Low Deck 400 Combos.... [Re: 70Dart499] #1346814
12/10/12 08:37 PM
12/10/12 08:37 PM
CNC ported Eddy RPM
Not unless the pistons are a high dome with a straight cut fireslot across the domes for the spark plugs Some mopars with B and RB motors in certain chassis have a issue with the headers using a set of angled plug heads What chassis and header brand and size primary pipes are you wanting to know about? Sorry to the O.P. about the hijack
Re: Low Deck 400 Combos.... [Re: badplymouth67] #1346815
12/10/12 10:45 PM
12/10/12 10:45 PM
ca
brownout Offline
brownout  Offline
ca
badplymouth67 what does the car weigh if you don't mind me asking.
Cody
Re: Low Deck 400 Combos.... [Re: brownout] #1346816
12/10/12 10:57 PM
12/10/12 10:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cody
THAT`S the magic number right there...........you see these low et`s for the motor at hand and are blown away till you find out the car weighs 2500lbs. It SHOULD run that fast........then there are some that truly have figured something out and have a well sorted out combo............
