Stewart Race Fuel pumps #1346723
12/06/12 05:16 AM
12/06/12 05:16 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
after our fuel pressure mishap in Le Mans this year (read more here http://www.olympia-charger.com/2012/10/le-mans-classic-2012-flashback-nr-1.html ), I'm considering to replace the original vintage double membrane fuel pump with something more modern.
What are your experience with the guys at Stewart Race Pumps ?
http://www.racepumps.com/
Re: Stewart Race Fuel pumps [Re: docford] #1346724
12/06/12 10:13 AM
12/06/12 10:13 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
says it all web page
home of the
Sox and Martin Hemi Duster
Re: Stewart Race Fuel pumps [Re: HEMIFRED] #1346725
12/06/12 12:07 PM
12/06/12 12:07 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I have no experience with a RACE PUMP. But have used a Clay Smith many years with excellent results.
Re: Stewart Race Fuel pumps [Re: rt66jim] #1346726
12/06/12 05:23 PM
12/06/12 05:23 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have an updated pump (pre-owned) that will be used to dyno my lo deck stroker over the winter and at some point may be used in the car when the engine is installed. My car is a street car so it will get lots of testing. I will be using a fuel cell with a sump that is higher than the pump so no check valve. Hopefully I don't end up walking home because of it.
OP you have a PM..
Re: Stewart Race Fuel pumps [Re: HEMIFRED] #1346727
12/07/12 02:39 PM
12/07/12 02:39 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Fred, that page is 5 years old, is here anything more current? Tim
Re: Stewart Race Fuel pumps [Re: astjp2] #1346728
12/07/12 06:12 PM
12/07/12 06:12 PM
Those guys sell the BEST bronze tipped fuel pump pushrod in the world for about 1/3 rd what Mancinis are---the bronze is Nascar grade from England etc--amazing units cheap!!!!!!!!
You don't have to fiddle with a website doing deals like that!!
Re: Stewart Race Fuel pumps [Re: rt66jim] #1346729
12/07/12 06:16 PM
12/07/12 06:16 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
the Clay Smith Cams website is under construction. Do you have a source where to buy them or get more information ?
Re: Stewart Race Fuel pumps [Re: docford] #1346730
12/07/12 06:35 PM
12/07/12 06:35 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You could use an electric pump to prime the system, here is something from the viper board...Tim
http://forums.viperclub.org/threads/6249...tarting-Problem
Re: Stewart Race Fuel pumps [Re: docford] #1346731
12/07/12 07:13 PM
12/07/12 07:13 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I ordered mine directly from CS. Just give them a call. 714-523-0530
