70 Road Runner - Window Regulator
#1346575
12/05/12 08:05 PM
12/05/12 08:05 PM
Posts: 1,379 Tennessee
WyleECoyote
Tennessee
1970 Road Runner - My brother is struggling with getting his front window regulator back in his freshly painted RR. Does anyone have the sequence of how to do this? Or the correct position of the pieces/parts as you reassemble and put it in the door? Diagrams? Or what gets assembled "outside" the door before you put it in - or what you need to assemble "inside" the door as you put it together? Thanks for the guidance! Ron
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 70 Road Runner - Window Regulator
[Re: a12rag]
#1346577
12/05/12 09:36 PM
12/05/12 09:36 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
He's pretty well right. When I did mine I stood a piece of wood in the bottom of the door about 10" high that held up the glass. It makes it a little easier to do everything else when you don't have to try and hold up the glass too. Sequence would be: vent window assembly with door glass attached align vent window frame and attach lower door glass all the way to bottom of door shell and install window fuzzies raise and support glass and install window regulator finally you may have to re-adjust angle of vent window frame with glass all the way up checking the clearance against the back glass and making sure the height at the rear matches the back window when its all the way up.
...FAFO...
[Re: safaritow]
#1346579
12/06/12 01:23 AM
12/06/12 01:23 AM
WyleECoyote
Tennessee
Thank you for the views and posts. I'll send you a picture of the shotgun hole in the door skin when he's had it....!!!!
