Can you reverse the rotation on a manual transmission? #1346453
12/05/12 04:43 PM
12/05/12 04:43 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I was bombing around in that desolate area between my ears and this came to mind.
Can you use a current production 5 or 6 speed manual transmission in an application that would reverse the direction of the input shaft? This assumes you want the output direction reversed as well.
I don't see there being an issue with the helical gears since they work the same in either direction. My concern would be thrust on the shafts.
Would lubrication be an issue?
I understand that some manual transmissions are using sprags that prevent reverse rotation so those would be out of the question.
- Stu Harmon
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346454
12/05/12 05:25 PM
12/05/12 05:25 PM
dogdays Offline
dogdays  Offline
I have never heard of a manual transmission that had this feature. It's possible that some twin-clutch boxes could, but that's way too new and expensive for me to think about.
Thrust would have to be taken into consideration, as it would be reversed and there may not be thrust provisions in sides that normally don't get thrust. I'm thinking about the countershaft.
Then there may be problems with oiling hole orientation and if the transmission has its own little oil pump inside (most don't, but I believe Gear Vendors overdrives do), it'd pump backwards.
What is this, create a V8 out of two Honda 4s?
R.
Re: Can you reverse the rotation on a manual transmission? [Re: dogdays] #1346455
12/05/12 05:53 PM
12/05/12 05:53 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
This would be a real one-off situation where the transmission would be mounted remotely and facing the wrong way.
The brainstorm involves something way out in left field so I won't bring that up.
- Stu Harmon
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346456
12/05/12 05:59 PM
12/05/12 05:59 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Look up the Boxster and 911 transaxle very similar but reversed. Also the 928 transaxles.
Re: Can you reverse the rotation on a manual transmission? [Re: bordin34] #1346457
12/05/12 07:28 PM
12/05/12 07:28 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I see those things every day. In fact, one of my techs just put a Carrerra 4S engine and transmission back in the car this morning.
They're backwards in the car but the packaging won't fit this application. The transmission is mostly forward of the axle centerline.
My bout with psychosis requires the transmission to be completely behind the axle centerline.
- Stu Harmon
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346458
12/05/12 07:34 PM
12/05/12 07:34 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
When has that ever stopped you in the past?
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346459
12/05/12 07:35 PM
12/05/12 07:35 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Seeking better front/rear weight distribution, feets is gonna move the Imperial's engine to the trunk!
Down to just a blue car now.
Re: Can you reverse the rotation on a manual transmission? [Re: 68HemiB] #1346460
12/05/12 07:57 PM
12/05/12 07:57 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
On the Boxster pretty much everything but the bellhousing of the trans is behind the centerline.
Re: Can you reverse the rotation on a manual transmission? [Re: bordin34] #1346461
12/05/12 08:08 PM
12/05/12 08:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Can't speak for 5-speeds but just thinking about trannys in general I can't see why they wouldn't work in reverse. In and 833, there is a thrust washer on either end of the cluster and I doubt it cares which way the thrust is going. As for those Porsche transaxles, they get run in reverse all the time for use with mid engines as opposed to rear engines - the issue with those is the oiling but otherwise they don't care which way they run.
Re: Can you reverse the rotation on a manual transmission? [Re: Stanton] #1346462
12/05/12 08:23 PM
12/05/12 08:23 PM
NW Pennsylvania
areibel Offline
areibel  Offline
NW Pennsylvania
Aren't there some 413/426 industrial motors that rotate opposite of normal rotation when running? You'd be all set for one of those!
Re: Can you reverse the rotation on a manual transmission? [Re: areibel] #1346463
12/05/12 09:36 PM
12/05/12 09:36 PM
Augusta, GA
Lightning Offline
Lightning  Offline
Augusta, GA
trying to do the Sierra RS200 setup?
Re: Can you reverse the rotation on a manual transmission? [Re: Lightning] #1346464
12/05/12 10:31 PM
12/05/12 10:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Feets wants to turn the Imp into a wheel stander.
Don't be the exception.
Re: Can you reverse the rotation on a manual transmission? [Re: 68HemiB] #1346465
12/05/12 11:59 PM
12/05/12 11:59 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
That's where they put it in most container ships.
- Stu Harmon
Re: Can you reverse the rotation on a manual transmission? [Re: bordin34] #1346466
12/06/12 12:03 AM
12/06/12 12:03 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Yeah, I forgot about the Box setup. We seldom pull those drivelines out. It's the 911s engine and trans combos that end up sitting on the racks when it comes to Porsches.
Andrewh told me over the phone that guys flip the Porsche transaxles frequently. swapping the ring and pinion side to side is common too.
I'll have to look into those a little more.
Perhaps I should go take some meds or something to get my head straight again.
- Stu Harmon
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346467
12/06/12 12:20 AM
12/06/12 12:20 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Also with the same input direction the boxster has an opposite output as the 911.
The Boxster should also be the same, in terms of rotation, as a 944 trans which you can buy for around $200 but they are very weak. Also known as Audi 016 trans.
A 968 trans should also be the same and its a stronger 6-speed. Same transaxle used in Audis up to the 2000s.
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346468
12/06/12 12:25 AM
12/06/12 12:25 AM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
There is/was (not sure if he's still kickin)a guy here in town who was a transmission builder. He had a 40 Ford, 2 door sedan with a small block Chevy and a Turbo 400 in it. Nice car too. Behind the Turbo 400, he mounted some kind of a 3 spd straight drive transmission backwards. Slip yokes of each transmission shared the same u joint. I can' remember much about how the driveshaft was hooked to the original input shaft of the 3 spd, other than it looked like a round plate welded to the shaft. Plate was close to the trans case, and had a cv joint/slip yoke combo thingy on it. He used it as an overdrive. Don't ask me how, but it sort of made sense when he explained it to me 30 years ago. Word on the street is, that the setup is still in the car and working. I saw it with my own eyes when I was in my early 20's,and the car is still here local. Next time I see it at a cruise in, I'll ask the dude that owns it now if I can peek under it to see if it's really still in there.
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346469
12/06/12 03:47 AM
12/06/12 03:47 AM
I remember way back when Feets claimed to have seen a functioning /6 mounted on it's side & I thought for sure that he had went off his meds & was in dire need of some hands on adult supervision but that was not the case as lo & behold he produced (& posted) a pic of it (it was powering a boat iirc)
Re: Can you reverse the rotation on a manual transmission? [Re: feets] #1346470
12/06/12 03:32 PM
12/06/12 03:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some transmission cases have cast-in ledges that direct lube to bearings...these ledges depend on lube thrown off of gears turning in a specific direction.
Re: Can you reverse the rotation on a manual transmission? [Re: John_Kunkel] #1346471
12/06/12 11:37 PM
12/06/12 11:37 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
Just had a thought if you want a strong, cheaper transaxle that can easily handle V8 power. Look for a snailshell transaxle from a 931, 924 turbo.
Re: Can you reverse the rotation on a manual transmission? [Re: bordin34] #1346472
12/07/12 10:09 PM
12/07/12 10:09 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Don't know your application but yrs ago when we were building old woods rigs and needed very very low gears , we would couple up two old three speed transmissions with a short jack shaft and put the two transmissions in reverse and you would end up with a super low gear .
