Re: Engine Oil Cooler
[Re: CHAPPER]
#1345602
12/03/12 11:51 PM
12/03/12 11:51 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
I have a thermostatically controlled cooler mounted behind the grill on my B-body Hemi. Same virtually instant pressure as before.
[Re: Crizila]
#1345605
12/04/12 09:49 PM
12/04/12 09:49 PM
Posts: 2,129 Vermont
TrWaters
Vermont
![](/ubbthreads/images/graemlins/eyes.gif) Any answers to my actual question will be appreciated, which was not "do I need an oil cooler?". Will there be a drainback problem with using a high mounted oil cooler? Thanks.
[Re: ahy]
#1345611
12/05/12 12:11 PM
12/05/12 12:11 PM
Posts: 7,506 Az
Crizila
Az
Oil coolers are usually mounted in front of the Rad... above oil pan height almost always. I don't see how "drainback" would be an (added) problem. The rest of the engine is above oil pan height also.
In my experience, they all drain back over time, check valves or not - including the factory installed units. It just amounts to a longer time before oil pressure comes up. Is that bad? Well, it aint good, and a poor trade off if you don't need to go there. Obviously, stock motors with lower compression and tighter clearances would suffer less than the other way around. My tow vehicle has one. Good application there, especially where I live - plus it doesn't sit for long periods of time between start ups. My race car ( with a filled block ) does not - and doesn't need one. If the OP KNOWS he is running outside (hotter) what his oil temp range should be, he needs one. Otherwise, he don't. IMO,in many cases they are installed unnecessarily. I was going to install one on my race car, but decided to install an oil temp gauge first, just to see where I was at. Good move on my part ( for a change ). I was well within the oil temp parameters for the oil I am using.
Fastest 300
[Re: Crizila]
#1345612
12/05/12 12:14 PM
12/05/12 12:14 PM
Posts: 1,106 Northeast
VincentVega
Northeast
I would do everything I could to prevent oil starvation on startup since that's where a ton of wear occurs.
Has anyone ever seen or used those devices that stores up some oil pressure, so that when you start the car, you can release that into the system for a shot of oil? I always wanted to use one of those.
Having said that, on any oil cooler, it's a great idea to use a thermostat. Same on a trans cooler (at least for street duty)
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: TrWaters]
#1345614
12/11/12 02:55 PM
12/11/12 02:55 PM
VincentVega
Northeast
For what it's worth, the factory mopar oil coolers were mounted in front of the radiator, at about center-block level. They are fed from the upper oil gallery, and where it came out of the block, there's a factory mopar checkvalve for anti-drain back. As long as you do something like that, you're at least as good as factory.
If you want that part number, I can get it for you. can probably still find them. I'm sure they are around as typical race parts, too.
[Re: VincentVega]
#1345615
12/11/12 05:37 PM
12/11/12 05:37 PM
Posts: 15,487 Florida
scratchnfotraction
I think mopar did more than just that for the stock oil cooler package.
my stock oil cooler from the 88 cop car was set up this way. full pressure feed to the cooler from the oil sender hole on the SB and back to the hollow fuel pump bolt to oil t-chain and return oil to the pan.
had timed oiling to the rockers on #2 & #4 cam journal. #1 cam bearing had full time oiling groove to #1 main bearing. #1,2,3,4,5 main bearings were full groove for better supply to oil rod bearings. standerd volume oil pump.
no check valve on mine , and I have found the bearings speced like this on at least 3 cop engines I have torn down. longevity was the goal on a stock oil cooler package.
the anti drainback valve on the oil filter should hold most of the prime on the pump side.IMO.
[Re: scratchnfotraction]
#1345616
12/11/12 06:29 PM
12/11/12 06:29 PM
VincentVega
Northeast
I'm looking at the check valve in the parts catalog for R/W body. Both big block and 360 uses it. The preceding page has H/F/N/G oil cooler w/ E58 small block engine, and you're right, no check valve. The implementation is basically the same except for that, fed via the upper gallery in the back, to a return in the fuel pump bolt.
If anyone wants it, the checkvalve PN is 2264514 (an old number).
A search comes up with this description: "Disc, oil pressure relief valve." At this point I'm wondering if it uses a stiff opening spring and closes off flow in the event of low pressure (to prevent starvation). Mine is around somewhere, I wish I could find it to take a look. I would love to know exactly what they were doing with it. I'd almost bet money it's just a simple check valve, but it's hard to find descriptions of minutiae like this
