Page 3 of 3 1 2 3
Re: New Hemi blocks [Re: Race&Resto] #1345429
12/08/12 09:38 PM
12/08/12 09:38 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
You had a valid question. I asked David about machining a generous radius into the block in that area to distribute the load. He said he is having a third party evaluate the design to see if any changes would in fact offer improvement.
If any of you have suggestions or questions feel free to call him. He is a very nice guy and will love to hear what you guys have to say.
David 865-310-7513
Re: New Hemi blocks [Re: Defbob] #1345430
12/08/12 11:57 PM
12/08/12 11:57 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
Post deleted by Performance Only
Despite Performance Only removing his comments from his posts, here are pictures of the dowels for the caps. [/quote
defbob... have you had any luck with the one piece rear main sealing... or have you not had the motor together yet? I seem to remember talking to a guy from HP products a number of years ago... he seemed to be a very nice fellow if I'm remembering correctly. At that time they had an aluminum one at the show and they were still working on the iron. I believe I was telling the guy what a real pain it was to get it right. Good to see that they are still after it and good luck to their company
Re: New Hemi blocks [Re: BIG BEAR] #1345431
12/09/12 12:05 AM
12/09/12 12:05 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I never got to run my first motor, there were some issues that prevented me from hitting the dyno. About the rear cap, I didn't use o-ring material on the rear cap sides, I just used silicone in the passages. I did use a Mopar Performance rubber 2pc rear main seal. I did not get to see if the silicone was enough to seal the rear cap. BTW, the rear cap was the hardest to remove
Re: New Hemi blocks [Re: Defbob] #1345432
12/09/12 12:09 AM
12/09/12 12:09 AM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
I figured that removal would be a real treat
Re: New Hemi blocks [Re: BIG BEAR] #1345433
03/29/13 02:14 PM
03/29/13 02:14 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Main Caps have been redesigned
Re: New Hemi blocks [Re: Defbob] #1345434
03/29/13 02:14 PM
03/29/13 02:14 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
2
Re: New Hemi blocks [Re: Defbob] #1345435
03/29/13 02:15 PM
03/29/13 02:15 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
3
Re: New Hemi blocks [Re: Defbob] #1345436
03/29/13 02:15 PM
03/29/13 02:15 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Re: New Hemi blocks [Re: Defbob] #1345437
03/29/13 04:35 PM
03/29/13 04:35 PM
Delray beach, Florida
P
Performance Only Offline
P
I spent quite a lot of time discussing the old main cap design with him at PRi. I'm happy to see he made the change.
machine shop owner and engine builder
Re: New Hemi blocks [Re: Performance Only] #1345438
04/07/13 11:20 PM
04/07/13 11:20 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I kinda need a hemi block, but I need a raised cam.
Re: New Hemi blocks [Re: camastomcat] #1345439
04/08/13 07:56 AM
04/08/13 07:56 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
He makes raised cams. He'll make any cam tunnel you want. My solid block has a 55mm roller bearing tunnel.
Re: New Hemi blocks [Re: Defbob] #1345440
04/08/13 11:54 AM
04/08/13 11:54 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
are these ready for sale?
Re: New Hemi blocks [Re: domingo] #1345441
04/08/13 07:11 PM
04/08/13 07:11 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I don't want to speak out of place, but they will be very VERY soon.
Page 3 of 3 1 2 3
