BBM solid or hydraulic roller cams on the street questi
#1345223
12/03/12 12:23 AM
12/03/12 12:23 AM
Posts: 516 Hanover, Ontario, Canada
Moparmatty
I've been getting some information lately that running roller cams on the street in our beloved Mopars is bad news. Ive been hearing stories of the distributor gears burning up rather quickly.
I want to run a hydraulic roller in a 500" motor. I also want to be able to drive it 2000 miles at a time if I choose to do so.
Is the burning up of distributor gears an actual problem that exists? If so, what's the fix?
GM and Ford small blocks have been running rollers for years from the factory with out issue.
Matt Tebbutt Ontario, Canada
Re: BBM solid or hydraulic roller cams on the street questi
[Re: Moparmatty]
#1345224
12/03/12 01:29 AM
12/03/12 01:29 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
FWIW, I built a 496 stroker with a solid roller cam w/ MP bronze oil pump drive gear for my buddies 70 challenger. He has put quite a few miles on it on the street over the last 5 years. I too have heard stories about them not lasting so, I pulled the oil pump drive gear to inspect it recently. It had little to no wear on it. Looked good enough to me, so I stuck it back in. The timing has stayed put and no bronze has been found in the oil filters. I wouldn't worry about it if I were you.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Moparmatty]
#1345226
12/03/12 09:52 AM
12/03/12 09:52 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I'm running a locking collar on the distributor shaft to keep the bronze gear from climbing up the cam gear. It stabilized the contact interface and decreased the wear on it. It helped stabilize my timing too.
About 1500 miles on the motor and it still looks good. If I have to change it again, I will have the next one cryogenically treated too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1345227
12/03/12 07:23 PM
12/03/12 07:23 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
How does the locking collar (I use two on my dist drive) help the oil pump/dist grive gear from climbing cam gear when the dist drive is fully seated against the oil pump/dist drive gear?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1345228
12/03/12 08:45 PM
12/03/12 08:45 PM
jbc426
West Coast, USA
The first few hours I ran my motor without the collars on the distributor shaft.
I could clearly see that the wear marks on the gear were bigger on the gear teeth than they should be with the gear all the way seated on the bushing. The only way the cam gear could make such long wear patterns on the gear, was if the gear was moving up off the bushing while the motor was running, causing the longer contact marks.
Once I installed the collars(I run two as well), there was no more free play. The bronze gear stayed down on the bushing in the block, and the wear pattern of the gear became smaller/shorter.
[Re: jbc426]
#1345229
12/03/12 10:32 PM
12/03/12 10:32 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Does anyone want to explain WHY this happens? What's different about a roller cam setup that causes this interaction?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: VincentVega]
#1345230
12/04/12 01:08 AM
12/04/12 01:08 AM
jbc426
West Coast, USA
I think they all do it to some degree, and that's part of the reason the timing jumps around without the collars on. The gear floats up and down as it spins within the up & down freeplay. That changes timing slightly.
Once you tighten it up using the collars on the distributor shaft, the free play is reduced and the gear has to spin within the reduced freeplay. It has less up and down motion because the collars restrict that motion.
The steel gears just handle abuse and wear better.
I wonder if anyone has tried cryogenically treating the bronze gears and seen what the results are.
