Part number help needed
#1344836
12/02/12 02:25 AM
12/02/12 02:25 AM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Im replacing the master cylinder on my dart and I need the rubber bushing that goes from the brake pedal push rod into the master cylinder (guess that holds the push rod in?) anyways I cannot find it on any of the auto parts sites. Any help would be greatly appreciated, Thanks. Just need to finish the brakes and ill be able to drive it for the first time in 2 years so this is a HUGE deal ![](/ubbthreads/images/graemlins/tongue.gif)
Re: Part number help needed
[Re: 69B3GT]
#1344837
12/02/12 03:00 AM
12/02/12 03:00 AM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
i made mine out of some rubber hose ,cut a small piece put it on the shaft in the groove then push into master cyl.mine wont pull out! seen later model stuff done that way....this is just a suggestion! do it at your own risk,but mine works fine.
[Re: CSK]
#1344838
12/02/12 03:04 AM
12/02/12 03:04 AM
69B3GT
Mira Loma, CA
I thought about trying it, just figured id try to find the right part. Already done enough work didnt want to chance something this small being the reason the car is wrecked.
Ive waited two years, guess another week wont kill me
[Re: 1_WILD_RT]
#1344840
12/02/12 04:07 AM
12/02/12 04:07 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://chucker54.stores.yahoo.net/brpubu.htmlDoctorDiff has them too...pretty easy to find...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
