Did 1968 GTX & R/T 4 spd come with Max cooling? #1344645
12/01/12 08:14 PM
12/01/12 08:14 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Did the 1968 GTX 4 spd. & R/T 4 spd come with Max cooling as std.? Thanks
Re: Did 1968 GTX & R/T 4 spd come with Max cooling? [Re: ragtop] #1344646
12/01/12 11:00 PM
12/01/12 11:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
"MAX COOLING" is a marketing/advertising term/phrase, I don't see any reference to it in '68.
In '68 the 4-spd manual transmission was a "no-charge" OPTION on the 440 b-bodies,
but it required you to purchase (mandatory OPTION for $138.90) an "axle package" (w/3.54:1 sure-grip & DANA 60) which also upgraded the cooling system (26" radiator, 7-blade fan, torque-drive fan clutch).
In 1968 it appears "Hi-Capacity Radiator" was the extent of the hype.
Re: Did 1968 GTX & R/T 4 spd come with Max cooling? [Re: ragtop] #1344647
12/02/12 10:32 AM
12/02/12 10:32 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
All know is my 68 GTX 4 speed dana had the 26 inch rad as shipped.
Re: Did 1968 GTX & R/T 4 spd come with Max cooling? [Re: Dodgem] #1344648
12/02/12 10:40 AM
12/02/12 10:40 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
snoop around on this site - http://www.hamtramck-historical.com/library-2.shtml
there is a ton of info there on options 'pet-names' and dealer brochures.
Re: Did 1968 GTX & R/T 4 spd come with Max cooling? [Re: ragtop] #1344649
12/02/12 12:27 PM
12/02/12 12:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's what I heard too as if it has a 440 4 speed, it also got a dana which started out with 354 gears which required 26 inch radiator.
