Weight diff. between an 18 & 23 spline 4 spd.? #1344544
12/01/12 12:31 PM
12/01/12 12:31 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
How much does the 18 spline complete 4 spd weigh over the 23 spline? Thanks.
Re: Weight diff. between an 18 & 23 spline 4 spd.? [Re: ragtop] #1344545
12/01/12 02:27 PM
12/01/12 02:27 PM
Probally not three lbs difference, if that much There both heavy
Re: Weight diff. between an 18 & 23 spline 4 spd.? [Re: Cab_Burge] #1344546
12/01/12 02:35 PM
12/01/12 02:35 PM
Kirkland, Washington
Pacnorthcuda Offline
I would say its a tossup as to WHICH is heavier than the other!
Re: Weight diff. between an 18 & 23 spline 4 spd.? [Re: Pacnorthcuda] #1344547
12/01/12 02:44 PM
12/01/12 02:44 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Thank you.
Re: Weight diff. between an 18 & 23 spline 4 spd.? [Re: ragtop] #1344548
12/01/12 03:49 PM
12/01/12 03:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
True, as long as the 23-spline doesn't have an aluminum case.
