my boss is building a stroker motor for his a-body and was wondering what kind of 1/4 mile times he could expect. im going to give you as much info as i can about the car so the experts on here can give me an educated guess. here is what i know about the car:
muscle motors 400>511 stroker kit(4.50 stroke)
ross pop up pistons 14.8.1
comp cam flat tappet cam 642 gross lift
1.6 crane roller rockers
edelbrock rpm 84cc heads.
727 trans with stock gear ratio
5300 stall 8" converter
tci trans brake valve body
dual holly 4150 hp converted to run alcohol with size 100 jets
dana 60 w/spool 4.30
4 link suspension
car weighs 3000lbs
and the driver has the reaction time of 80 year old lady with glaucoma
any guesses?
