MP 284/528 Cam on infinate back order. Other choices?
#134341
10/09/08 03:44 PM
10/09/08 03:44 PM
Posts: 238 St. Catharines, ON
NewMemberAgain
super street
super street
St. Catharines, ON
Well I have called my Mopar Dealer quite a number of times, so much so, that they have no idea when it is IF ever coming, so I cancelled my order.
Both the 3" inboard kit and the MP .284/528 cam show no signs of showing up.
Now, I am at a loss.
I really wanted a cam on the 114 lsa, and the MP cam, even though its OLD, it just fit the bill so simply.
I had already looked at Crane, Comp even Hughes that is what I currently have buts it's on a 108.
Hughes how ever does have a few Hydraulics with 112, with some pretty big specs for a hydraulic.
Who else does a 114 lsa?
Here is a quick breakdown of motor and useage.
440 .55 over Ross Pistons 10:1 compression Stock Eddy Heads Hughes 238/245 546/560 108 lsa 582/597 on 1.6 OLD Offy Dual Quad Intake with 625 Carters 1 3/4 CPPA Headers 4.56 w/ MT ET Street 28 X 11.5
Dodge Dart Sport
What is going to change? NEW Eddy Dual Quad Intake 4.56 w/ bigger maybe 325/50/15? Maybe 3.91's
This is a street driver, so vacuum was a concern. Giving myself that 114 lsa I though would do the trick.
Bryan
Re: MP 284/528 Cam on infinate back order. Other choices?
[Re: NewMemberAgain]
#134342
10/09/08 03:47 PM
10/09/08 03:47 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
if you call comp, crane or hughes, they will grind you a cam with whatever lobe center you want.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Kirk_Ingram]
#134345
10/09/08 04:18 PM
10/09/08 04:18 PM
whats the 114 lsa going to give you over the 108? and what will it take away from you?
[Re: AdamR]
#134348
10/09/08 05:37 PM
10/09/08 05:37 PM
the .528 is on a 112, not a 114. The new version of the 484 and 509s are on 114s. The 528 is a solid and the 484,509s are juice cams.
The wider LSA will have a broader curve, idle better, build higher vacuum and have less over lap which would be better with a restrictive exhaust.
so whats the down side? less peak power? less total power under the curve?
how much better is the vacuum with a 112 vs a 108?
I have a 250 at .050, lift .565/.575 on a 108 installed at 105. running about 7" at idle
[Re: BRawls]
#134351
10/10/08 08:39 AM
10/10/08 08:39 AM
cucu-
I think you are confusing Lobe Seperation Angle and intake centerline. You can't change the LSA, it's ground in the cam. Centerline can be dialed in.
im not confusing them. I was just reporting my cam had a 108 LSA and it was installed at 105 centerline. I know the LSA is built into the cam and that the centerline can be installed wherever
#134352
10/10/08 09:25 AM
10/10/08 09:25 AM
Posts: 535 Ohio
racerAL
Ohio
Mopar Performance part P4120659 284/528 cam is NOT on back order....i could have one in my hands first thing Mon. morning...not real sure why your dealer is telling you they are on B.O ...if you need some help getting one let me know,i'am sure i can it for you. ....
[Re: racerAL]
#134353
10/10/08 10:03 AM
10/10/08 10:03 AM
NewMemberAgain
super street
super street
St. Catharines, ON
I just RE-ORDERED it again. It turns out that 'somebody' never even placed an order for me! I just spoke to the parts manager, and a 'Oh Yeah' came from the back room. So..... now it may be upto a week to ten days as I live in Canada, so both items are coming from US. Fingers crossed.
#134354
10/10/08 01:28 PM
10/10/08 01:28 PM
DaytonaTurbo
Manitoba, Canada
Fingers crossed.
How much is your Dodge dealer charging you for MP parts? Last time I went to my local dealer and asked about mp parts was a couple years ago. Asked how much for their set of MP big block headers. The catalog online at the time had them for $150 USD, so I figured a bit more because we're in Canada. Guy looks on the computer and tells me the only set they have is one province over and they wanted over $350! I walked out the door and have not asked about MP parts since.
Re: MP cam prices
[Re: redmoparman]
#134358
10/11/08 10:09 AM
10/11/08 10:09 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
you will love that cam,we just put one in my boys duster. it makes awesome power.
good to hear. my 440 has that cam decent heads and will probably get a 6-pack.
