reusing head bolts
#1343050
11/29/12 06:33 PM
11/29/12 06:33 PM
Posts: 1,630 North Central Florida
eightlitermopar
FOR THE RECORD: I have new head bolts for my 318 I am currently putting back together. I was wondering; we have been told to not reuse head bolts, they stretch, etc. Who has actually resued head bolts and seen a failure from doing this? This is just a question, not an argument starter, just curious. eightlitermopar
Mopar or no car
Re: reusing head bolts
[Re: RapidRobert]
#1343052
11/29/12 08:30 PM
11/29/12 08:30 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
no failures from reusing here & on a 318 I wouldn't give it a seconds' thought
Have reused head bolts for years and never had a problem or given it thought.
[Re: ahy]
#1343055
11/29/12 11:25 PM
11/29/12 11:25 PM
eightlitermopar
These were the stock bolts that were installed from Ma mopar. Hmmm...maybe I'll return my head bolt set then and get my 33 bucks back. Where this is a budget build, I could use the money. Acutally, I already opened the new box of bolts so they are non-returnable now. I am putting '96 magnum heads on this old 318 so I wanted to be sure they were the right head bolts. However, this is good information to know for the future! Thanks!
Mopar or no car
[Re: RapidRobert]
#1343059
11/30/12 12:14 PM
11/30/12 12:14 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Magnum headbolts are NOT torque to yield, and I've re-used them several times without any problems. however, on a high compression performance build, I would suggest going with new ARP hardware anyway.
but for a mild build, stock bolts are fine. mine has re-used stockbolts, and it's about a 350-ish hp engine. (285 RWHP)
However, Magnum head bolts ARE different than LA head bolts. I found this out when I ordered a set of ARP hardware for edelbrock heads off Mancini. They arrived with 3 different length bolts. The Magnums use 2 length bolts, 5 long ones down the middle of the head, and 5 short ones for the base of the head below the exhaust ports. When I called Mancini they confirmed that the LA heads use a different bolt set than a Magnum bolt set, and took the opened set of LA bolts back without any problem, and sent me the correct head bolts instead.
**Photobucket sucks**
[Re: RapidRobert]
#1343061
11/30/12 04:13 PM
11/30/12 04:13 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I believe the mags take a unique bolt (P4876759). I have a set for a Magnum swap also & I'm not sure if they are torque to yield or not. You have used ones that you were considering reusing? If not TTY then the thread gauge check sounds excellent & I'd just lightly wire brush em clean & good visual for nicks that would screw up your torque readings.
magnum INTAKE bolts are supposed to be TTY, IIRC, not the head bolts. and there's 1 or 2 that are different length for an LA, so LA head bolts won't work.
I reused mag head bolts when I put mag heads on an LA 318 roller, didn't have any problems.
[Re: patrick]
#1343062
12/01/12 01:01 AM
12/01/12 01:01 AM
eightlitermopar
thanks for the info. My brand new head bolts ARE for magnum heads. I was curious if they were different, and now I know.
I'll let you know as I progress.
eightlitermopar
Mopar or no car
[Re: dogdays]
#1343065
12/03/12 06:02 PM
12/03/12 06:02 PM
70Cuda383
Marysville, O-H-I-O
Does anyone know if there are engines out there that DO TTY the bolts that hold on the heads? Seems like there HAS to be a few of them, otherwise there'd be no myth about having to replace them every time
and just for the record, I was talking about the intake manifold bolts when I said that I replace them. the originals always look like junk because of the galvanic reaction taking place between the 3 different metals (whatever alloy the bolts are, the cast aluminum of the intake, and the cast iron of the head.)
head bolts NEVER look bad when taking apart an engine.
[Re: ahy]
#1343068
12/04/12 01:22 AM
12/04/12 01:22 AM
eightlitermopar
So what would the downside be:
to getting the right size intake bolts from a local hardware store in a grade 5 or 8 so that they can be reused in the future? Do they HAVE to be replaced with a TTY bolt?
Also, what is the torque spec on these magnum intake bolts? TTY or otherwise?
Mopar or no car
[Re: 70Cuda383]
#1343069
12/04/12 01:33 AM
12/04/12 01:33 AM
Posts: 7,052 Madera, CA.
MowP4rsn
Madera, CA.
I'm stretching my brain a little trying to remember this (see what I did there? ) but I seem to recall the Neon 2 liter had TTY head bolts.
