B-Body steering box replacement #1342813
11/28/12 11:05 PM
11/28/12 11:05 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
ON a 67 Hemi B-Body with stock exhaust manifolds, is it possible to remove and replace the steering box with the motor in the car??
thanks
Re: B-Body steering box replacement [Re: hemi67] #1342814
11/29/12 10:31 AM
11/29/12 10:31 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
thanks
I would not hesitate to try it , I would think it can be done if you remove the Steering column and loosen the exhaust.
You will need to remove the pit men arm.
might have to lift the left side of the engine some with a block of wood and floor jack but not sure .
Also might need to remove the driver-side exhaust manifold.
But i would think it can be done to answer your question.
1969 Dodge Charger 1969 Dodge Superbee
Re: B-Body steering box replacement [Re: hemi67] #1342815
11/29/12 08:41 PM
11/29/12 08:41 PM
robertop Offline
robertop  Offline
I replaced that box on my 69 Hemi Roadrunner, and it was a tight job, especially given the task of working on my back and the considerable weight -for me!- of the darn thing, I did not have to do anything to the engine or exaust manifold either, but on a 67 it might be different.
Re: B-Body steering box replacement [Re: robertop] #1342816
11/29/12 10:40 PM
11/29/12 10:40 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
I am pretty sure the 67 and 69 engine compartment is the same. I am going to remove the steering column anyway since it needs to be changed to a power steering one .
Thanks for your help.
Re: B-Body steering box replacement [Re: hemi67] #1342817
11/29/12 11:22 PM
11/29/12 11:22 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
Yes, I just had mine out. removed the exh. manifold and column and pit man arm. was not that bad!
HEMI,S ARE FOREVER!!!
