Confused....LA motor mounts #1342689
11/28/12 06:31 PM
11/28/12 06:31 PM
North Central Florida
E
eightlitermopar Offline OP
E
Ok, I confused myself. 1969 B body with a 318. Do I have the motor mounts on the right sides?
This picture is the passenger side?
Mopar or no car
Re: Confused....LA motor mounts [Re: eightlitermopar] #1342690
11/28/12 06:31 PM
11/28/12 06:31 PM
E
E
Drivers side?
Mopar or no car
Re: Confused....LA motor mounts [Re: eightlitermopar] #1342691
11/28/12 11:02 PM
11/28/12 11:02 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
You got it.
Re: Confused....LA motor mounts [Re: Dan Halen] #1342692
11/29/12 03:59 PM
11/29/12 03:59 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
yes u are correct, however if you look at the passenger side it has 3 mounting holes not four, some newer 318 blocks have a mounting tab on the block and there wont be a hole on the passenger side mount to line up to,easy fix,bolt the mount to the block and use a marker,pencil,ice pick to draw a circle on the steel mount where the bolt hole would be.drill it out and your good to go. the hole will be directly across from the hole on the other side of the mount.
Re: Confused....LA motor mounts [Re: Joesixpack] #1342693
11/29/12 06:29 PM
11/29/12 06:29 PM
E
E
Thanks guys! I thought about it too much and got turned around. Thanks for the info!
eightlitermopar
Mopar or no car
