2000 Ram 1500 4x4 reverse broke still drives foward #1342667
11/28/12 05:25 PM
11/28/12 05:25 PM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
The truck has 160,000 miles on it anyone have any ideas. Looking for an inexpensive fix (though I know thats probably not realistic). I just got back to work after being out on disability for 7 weeks due to a heart attack and we just bought my wife a long over due replacement for her 2000 300M that had 150,000+ on it. Money is very tight right now so any helpful suggestions are appreciated.
Re: 2000 Ram 1500 4x4 reverse broke still drives foward [Re: JCCuda] #1342668
11/28/12 06:38 PM
11/28/12 06:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the trans still has all 3 forward gears but no Reverse the problem is in the rear band/servo. Pull the pan and make sure the rear band lever is still attached to the band by pulling down on the lever; if there is resistance to pulling but the lever pulls down more than a half inch adjust the band. If the lever is hanging loose the link has popped out or the band/linkage is broken.
The servo could also be the problem, check for a torn seal or dislodged spring retainer.
Re: 2000 Ram 1500 4x4 reverse broke still drives foward [Re: JCCuda] #1342669
11/29/12 04:33 PM
11/29/12 04:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Agreed,
Does it have a solid forward motion if you pull it down in manual low ?
Re: 2000 Ram 1500 4x4 reverse broke still drives foward [Re: John_Kunkel] #1342670
11/30/12 02:05 PM
11/30/12 02:05 PM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
I'm hopefully going to pull the pan this weekend so I'll check. Thanks for the tips.
Re: 2000 Ram 1500 4x4 reverse broke still drives foward [Re: gtx6970] #1342671
11/30/12 02:09 PM
11/30/12 02:09 PM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
Agreed,
I didn't pull it into low I just put it in drive and it drove. I will check that. How is that different from first gear in drive? Does it apply the band differently?
