Video from SCSN 8 #1342640
11/28/12 02:32 PM
11/28/12 02:32 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Just a quick video of round 2 of Hot Street from SCSN 8 of the Barracuda. It was against Mike Demayo who runs a SB Ford coombo at about 2700lbs. We are at 3340 one of the things we will be addressing before it goes out and races again atthis level. We are heavy for the class, so getting weight out and moving it where it is needed is a goal.
Back to the set up. This is a shortened version of the round, we cut about 4 minutes as we had a bit of a staging battle going on as I knew he was not going to go in first. Needing every advantage I could get I decided that we would break that habit before the race. They are very anal about engine temps on their car so I figured he would give in first, plus I knew I was not movong in period. From what I heard there were lots of people hooting and cheering while it was going on, you can hear a couple on video. It did work as I got a decent starting line advantage. Was actually dissapointed with it only being a .033 lite. At any rate Mike went on to make his best pass of the weekend on this pass and took us out.
We are still learnign and trying to ake this thing work better. Every pass is a test pass for us as we are learning something on each run. tbhis weekend was no different. We have been fighting an intermittent problem ,actually more than likely always there to some extent looking back. We had found an issue that has plagued us all summer long the night before before last qualifier. Turns out we had a bad coil that was breaking up intermittently, sometimes really badly and car would not run and other times just acting like it was loaded up. Put a new one on and Viola car ran great. The issue caused us to go way back on what we had been doing to attempt to fix it. As a result we missed the set up on the last qualifier Saturday night, so first round was an entirely new deal, as usual for us. We did manage to run better in first and second round than we had all weekend, finding two tenths over Sat night qualifying. Round two we made a big change to the fuel curve looking at improving some more and went to far and were lean the entire pass, but really lean up top. Woudl be nice to go into a race with no issues so we coudl work on the car set up and power application. Oh well maybe whenever we get back to racing it.
Anyway here is the video. Sorry for the long set up must be the MoparBilly in me
https://www.youtube.com/watch?feature=player_embedded&v=LpnaL2UWaGM
Re: Video from SCSN 8 [Re: Al_Alguire] #1342641
11/28/12 03:05 PM
11/28/12 03:05 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Boy that little small block put the whoop on yah!!
LOL just messing with yah Al
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Video from SCSN 8 [Re: FASTFISH420] #1342642
11/28/12 03:07 PM
11/28/12 03:07 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Al I was wondering why you have that car sitting so high in the rear end?? Mine was sorta like that until I took it to Holt and he lowered it abunch and helped my car out abunch..
Re: Video from SCSN 8 [Re: FASTFISH420] #1342643
11/28/12 03:25 PM
11/28/12 03:25 PM
Las Vegas
Las Vegas
The ride height is also one of the things that will be addressed. It was built at this ride height and we have left it as is for now. But if we decide to keep doing this stuff it is priority one, with weight being secondary. Just more money right Still on the fence about what to do with the car. Been thinking lately that SS is looking really good..
FWIW we have been 164 and change and that pass should have been there as well if we had not gone over to far on the bleeds. Really laid over on top. Also that was only a 1.29 60' Of course if I had a SB we know it would have been faster Unfortunately I would have to weigh almost as much with a combo like yours, IIRC it was only 70lbs less. They dont understand Mopar stuff and those heads are "exotic" yet a head like the mustang runs is not. Even though they are one off ppieces that say Edelbrock on the end
Re: Video from SCSN 8 [Re: Al_Alguire] #1342644
11/28/12 03:30 PM
11/28/12 03:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
HOT DAMN that thing leaves hard ............. I would think if you could controll that wheelie it might pick up.........
Re: Video from SCSN 8 [Re: Thumperdart] #1342645
11/28/12 03:37 PM
11/28/12 03:37 PM
Las Vegas
Las Vegas
Dom you are correct..A big part of that is the ride hieght. We usually dont have it going quite so high but with all the new stuff we were doing on the engine we basically left the chassis alone for Sunday other than a small shock adjustment to keep it down some. if you look it did not hit the bars at all on that pass. We chalk them pretty good every pass. We were a couple more tweaks away from being fast, both engine and chassis.
Re: Video from SCSN 8 [Re: Al_Alguire] #1342646
11/28/12 05:51 PM
11/28/12 05:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know some swear they`re faster in the air and they may be but most cars at your power level I`ve seen, go quicker/faster leaving more like a Pro Stock car car than you are leaving now. Nice to have that problem though..............
Re: Video from SCSN 8 [Re: Al_Alguire] #1342647
11/28/12 06:21 PM
11/28/12 06:21 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
WOW Al..that was a CLOSE race & you're 640 lbs heavier than the stang.
You left pretty hard & I think if you can get 400lbs + off the cuda,
it'd be a different story. Glad to see you getting it dialed in.
You can always save the red 68 for SS?
Re: Video from SCSN 8 [Re: Triggerfish] #1342648
11/28/12 07:13 PM
11/28/12 07:13 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
al is this setup the ps hemi motor
Re: Video from SCSN 8 [Re: cesar perez] #1342649
11/28/12 10:01 PM
11/28/12 10:01 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I want to ride in the car, darn it! Where is the GoPro?
Sitting in the stands, I heard a bunch of, "Here comes that 4 wheel drive Barracuda" comments! Chevy guys never know when to keep quiet...
It was a stellar effort Al, very proud of the job you guys did at that race!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Video from SCSN 8 [Re: Al_Alguire] #1342650
11/28/12 10:33 PM
11/28/12 10:33 PM
Lehigh Acres, Florida
rickstershemi Offline
Bet that was fun Nice lap....scared me at first when you got out of the grove and didn't lift was on your side
Rickster
Re: Video from SCSN 8 [Re: rickstershemi] #1342651
11/29/12 02:54 AM
11/29/12 02:54 AM
Las Vegas
Las Vegas
Ceasar yes this is the 99 Hemi. Still pulling a fair amount of timing for a second or so in the video.
Billy, I dont have that on on GoPro but here is round 1, car made the same move then too. They look really good in HD
http://www.youtube.com/watch?v=oJHgB1py7Iw&feature=plcp
Rick, One of the fun parts about a small tire car is you get to do some driving. Not so much of a point and go thing
Re: Video from SCSN 8 [Re: Al_Alguire] #1342652
11/29/12 03:06 PM
11/29/12 03:06 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You guys definitely stepped up well on race day. You'll get it sorted out soon.
Re: Video from SCSN 8 [Re: BobR] #1342653
11/30/12 05:09 AM
11/30/12 05:09 AM
Las Vegas
Las Vegas
Bob one of these days we will get it to work right Finally on the right path I think...
Re: Video from SCSN 8 [Re: Al_Alguire] #1342654
11/30/12 10:07 AM
11/30/12 10:07 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Cool Vids, thanks!
68 Barracuda Formula S 340
Re: Video from SCSN 8 [Re: Bad340fish] #1342655
12/01/12 11:33 PM
12/01/12 11:33 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
sweet run, Al your coming along nicely with her...
Re: Video from SCSN 8 [Re: B1Fish540] #1342656
12/02/12 02:03 AM
12/02/12 02:03 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Looks like it going the right way Al. Thanks for the videos. I love watching both of your cars. I am a little partial though! Keep up the good work. Beep
Re: Video from SCSN 8 [Re: Bigbeep] #1342657
12/02/12 02:53 AM
12/02/12 02:53 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I agree! Looks awesome! I hope to get to MATS next year hope to see ya run!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Video from SCSN 8 [Re: HOTMOPR] #1342658
12/02/12 01:46 PM
12/02/12 01:46 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
DAYUM!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
