use the thin (.028" thick) Mr. Gasket head gasket for compression. with a '85-up shortblock and mag heads, you'll get an honest 9:1
is your copcar a 2bbl or 4bbl? 2bbl, it'll have a roller cam if it's a 2bbl...in that case, just get that cam regound by bullet cams.
if it is a flat tappet, you could buy a roller cam and use used OEM magnum pushrods, lifters, and lifter retention parts
if you're intent on sticking with a flat tappet, I'd use a lunati voodoo 60400 or 60401 instead of the 340 cam. I'll probably idle better and make more HP and torque
