71 R/T or GTX fuel line diameter #1341900
11/27/12 12:39 AM
11/27/12 12:39 AM
S.E. WI
allmopar Offline OP
allmopar  Offline OP
S.E. WI
I am trying to find out if all of the 71 b-bodys with either the 440 or hemi had the 3/8" dia. fuel line or if some had the 5/16" ?
I just ran across something odd on my 6-pack car. It has the 5/16" dia. line from the gas tank to the fuel pump. Yes it is a real 6-pack car and I have owned it since 1977. I also know the person who ordered the car new out of Chicago and he never changed it. He had the dealer undercoat the car when new and the tar undercoat is still on the lines and they still have the factory crimp clamps on the hose ends.
I wonder if it was a goof up on the assembly line or did some cars not get the 3/8" lines ?
I remember about 10 years ago a friend was restoring his 69 GTX and his had 5/16" lines but he figured it was a California emissions car because it had a vapor return line also.
Re: 71 R/T or GTX fuel line diameter [Re: allmopar] #1341901
11/27/12 02:36 AM
11/27/12 02:36 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought that only Hemi cars got the 3/8" line.
Re: 71 R/T or GTX fuel line diameter [Re: Kern Dog] #1341902
11/27/12 02:39 AM
11/27/12 02:39 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I'm pretty sure my 440 4v R/T has 3/8" line....
Re: 71 R/T or GTX fuel line diameter [Re: allmopar] #1341903
11/27/12 02:52 AM
11/27/12 02:52 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Supply-3/8
Return to canister-5/16
Re: 71 R/T or GTX fuel line diameter [Re: RSNOMO] #1341904
11/27/12 11:01 AM
11/27/12 11:01 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've owned a few 69-72B with 440-4bbl and all had the 3/8" and 1/4" return line.
Thought the return is 1/4 not 5/16 but not positive.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 R/T or GTX fuel line diameter [Re: moparmarks] #1341905
11/27/12 11:08 AM
11/27/12 11:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Return is 1/4"
Re: 71 R/T or GTX fuel line diameter [Re: Challenger 1] #1341906
11/27/12 06:18 PM
11/27/12 06:18 PM
S.E. WI
allmopar Offline OP
allmopar  Offline OP
S.E. WI
Thanks for all the input, Yes I agree the line should have been a 3/8" not a 5/16". I think it must have been a mix up on the assembly line. My return line is a 1/4" line and the vapor line is a 5/16".
This is maybe part of my problem when I raced it at the strip The carbs would run out of gas at 9o mph.
I am going to change the line to 3/8" but am I going to see any improvement when the fuel lines from the pump to the carbs are 5/16" ?
Re: 71 R/T or GTX fuel line diameter [Re: allmopar] #1341907
11/27/12 08:00 PM
11/27/12 08:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My 440 magnum had a 5/16" line. I've gone 12s at 109 mph, others have gone 11s with a 5/16" line.
Re: 71 R/T or GTX fuel line diameter [Re: allmopar] #1341908
11/27/12 08:05 PM
11/27/12 08:05 PM
Cincinnati, Ohio
Cincinnati, Ohio
Don't worry about discharge, 5/16" is fine.
Ideally 3/8" in and 5/16" out, that's a good setup.
You using a mechanical fuel pump?
