Steel Wheel source?? #1341635
11/26/12 01:51 PM
11/26/12 01:51 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Headed out to the junk yard for some 15" steel wheels. What are some cars I should be on the look out for for some 15 x 7s??? How bout 15 x 6s?
Big bolt pattern of course.
Thanks!
Re: Steel Wheel source?? [Re: mopowers] #1341636
11/26/12 03:07 PM
11/26/12 03:07 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
80's diplomatss , grand fury's , , 5th aves ... will have 15x6/7's
Re: Steel Wheel source?? [Re: JohnRR] #1341637
11/26/12 04:17 PM
11/26/12 04:17 PM
PEI Canada
chromedome426 Offline
PEI Canada
Also Dodge 1/2 tons & vans built before 1985. Around 85 or 86 they went from 4 1/2" bolt circle to a 5" bolt circle.
Re: Steel Wheel source?? [Re: chromedome426] #1341638
11/26/12 05:22 PM
11/26/12 05:22 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
2wd trucks went to 5.5 in 85. The 4wd went to 5.5 in 80.
As stated 5th aves and dippys are your best bet. I didn't realize they were hard to find otherwise Id have had tons to sell from jy trips
Re: Steel Wheel source?? [Re: 76dodgeboy] #1341639
11/26/12 05:23 PM
11/26/12 05:23 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I have a set but their promised to another member when he is ready
