Anyone ever swap a 3.8 where a 3.3 came stock? #1340917
11/25/12 01:57 AM
11/25/12 01:57 AM
North Central Indiana
C-Tech Offline OP
C-Tech  Offline OP
I have a Caravan with a 3.3 that's got a rod knocking (opened it up today spun a rod bearing) I can buy a 3.8 for about the same money but the trans gearing and ECM/TCM will still be 3.3 anyone tired this before?
Kevin
Re: Anyone ever swap a 3.8 where a 3.3 came stock? [Re: C-Tech] #1340918
11/25/12 01:00 PM
11/25/12 01:00 PM
Central NY
GarageDodge Online content
GarageDodge  Online Content
Central NY
It will work no problems,just make sure if not the same year they will interchange.3.3&3.8 same years will work.
Re: Anyone ever swap a 3.8 where a 3.3 came stock? [Re: GarageDodge] #1340919
11/25/12 01:06 PM
11/25/12 01:06 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The only issue I can see you having is if one has EGR and the other does not. You can still make it work but you may have to swap the upper intake.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
