Building a 440 stroker - Help! #1340837
11/24/12 10:48 PM
11/24/12 10:48 PM
Staten Island, NY
Chrisn68 Offline OP
Chrisn68  Offline OP
Staten Island, NY
Hi All, I'm new to the board, and was hoping to get some input/advice on a few things.
I have a 68 Charger that is 14 years into a never-ending restoration. The car is not numbers-matching and would be considered a resto-mod, although it is mostly true to stock appearance.
After the existing 383 block self-destructed, I am going to convert to a 440 stroker, which will bring it up to around 500 cubes, using aftermarket aluminum heads and roller rockers and keeping it all under a stock hood. It will be a weekend cruiser, not a track star or street racer, although as you would expect, I want it to really have some kick on occasion. I doubt it would ever see RPM north of 6000-6500. My engine builder is trying to convince me of a few things that I am not sure of, so any thoughts would be greatly appreciated.
1) I already have a TTI exhaust system, and was planning to use 1-7/8 TTI headers, which will mate up easily to the existing TTI exhaust. He feels I should use the Hooker Super Comp headers. Any real reason to do that?
2) I already had a Mopar orange box electronic ignition, and since I cannot reuse the 383 distributor, was planning to simply get the appropriate MP distributor that would fit the 440. He wants me to convert to an MSD system. I am hesitant to start cutting up the new wiring harness, which I think is necessary to add the MSD. Any real reason to change over to MSD?
3) He doesn't like my Edelbrock AVS Thunder series 800cfm carb, and wants me to change over to a Holley 950. Again, any real reason to do that?
All in all, the sky is not the limit on pricing, but I'll spend it if it would really make a difference for some of the parts. I'd love to re-use as many of the existing parts as possible, as long as it won't compromise the engine. Thanks!
Re: Building a 440 stroker - Help! [Re: Chrisn68] #1340838
11/24/12 11:05 PM
11/24/12 11:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You need to ask yourself what am I build ing this car for? A stroker is great and all but a stock 440 or even 383 can run just fine for most applications. It all depends on what you buy and how much work it needs. TTi's are a waste of money unless you need a 2" tube. My junk runs 11.30's w/ cheap a$$ 1 3/4" headers. MSD is nice but just get a shelf 440 distrib and roll. The 800 should be fine. a 950DP is a great carb but seems like it's over-kill for what you want. Look around for a short or long block. This kit is advertised on e-bay, not made in the US but it's a hell of a deal. http://www.ebay.com/itm/THE-DEFINITIVE-3...7a3&vxp=mtr
toss that on top a a .030 over 10:1 440 w/ a 240ish, 520ish cam and roll.
Coming soon!!!!
Re: Building a 440 stroker - Help! [Re: Chrisn68] #1340839
11/24/12 11:09 PM
11/24/12 11:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well first 500 to 512 is the way to go cost the same to build as a stock stroke when you are starting from scratch! AND there is no replacement for cubic inch displacement!!
If he wants you to go to Hooker super competitions over TTI not only must he be old (they are so 1982) but a sadist as well cause the fit like crap I had 2 sets on my GTX 85 till 2005 never ever again TTI all the way!
Go with Edelbrock heads and RPM performer intake.
if your going with edelbrock Victors maybe a Indy dual plane but ported edelbrock RPMs will more than do the job!
I do like the upgrade to the Holly 950
No reason not to run the mopar dizzy I switched to MSD and gained?? wait for it nothing but a rev limiter.
Then I switched from my recurved mopar 440 dizzy to a MSD and gained?? wait for it O The bearings in an MSD are longer lasting at High rpm drag racing than the dizzy's bushings But that is it!
and you can buy rev limiters hear is one
http://www.summitracing.com/parts/msd-8728/overview/
Re: Building a 440 stroker - Help! [Re: Chrisn68] #1340840
11/24/12 11:26 PM
11/24/12 11:26 PM
Welcome! I would get Andy Finkbeiners' stroker bible. I'd keep the carb & as said get a new or used 440 electronic dizzy. You can experiment later after you're up & running. Too long of down time from poor plannning/spending money on the wrong areas/parts is the cats' ass & a common pitfall leading to unfinished projects. Do your homework & ask plenty of questions (it's free). Me and a customer are stroking a 440 & we're going with sources' 4.5" stroke kit (~535 cubes ), not sure on heads yet
Re: Building a 440 stroker - Help! [Re: RapidRobert] #1340841
11/25/12 12:03 AM
11/25/12 12:03 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Ditto on keeping the carb and headers. They will work fine for the time being. A MP distributor with the proper timing curve will work just fine also. I built a 10 to 1 496 for my buddies challenger that runs very well with out of the box parts. I used a set of OOTB RPM eddy heads, small 260 @.050 solid roller cam, comp pro magnum 1.5 rockers, Holley SD intake and 1050 annular 4150 series carb. The engine is about as docile as can be and makes goobs of power from off idle to 6500 rpm. You might consider the Holley SD intake also over the RPM for more hood clearance too in your application.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Building a 440 stroker - Help! [Re: 71yelladustr] #1340842
11/25/12 12:27 AM
11/25/12 12:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would use the headers if you already have them as they will work fine. I had 1-3/4 headers on my old 440 thet went 11.49 best. I bought 2" for my 493 as I wanted a larger header for it since I use Indy EZ heads.
I am also still using the MP orange ign ECU on my 63 and it has run in the 10's with no problems so far. We took the orange box ECU off my sons Dart and he put the MSD on it and gained no performance at all. But MSD is one of the best ign system's out there. God luck , Ron
Re: Building a 440 stroker - Help! [Re: Chrisn68] #1340843
11/25/12 01:03 AM
11/25/12 01:03 AM
What your engine builder is trying to accomplish is to get the max power out of the stroker, not make you happy with the choices you want to make I say put your foot down and go with what you want to pay for, you can always swap parts later, if you want to
Re: Building a 440 stroker - Help! [Re: Cab_Burge] #1340844
11/25/12 08:38 AM
11/25/12 08:38 AM
IN
ahy Offline
ahy  Offline
IN
On the headers, TTI's are great. Well made, fit as advertised and flow well. They should match up well with the TTI exhaust you have. On the carb, 800 is enough. Carb brand comes down to preference and what you are familair with tuning. On the rockers, go with good ones. Aluminum fatigues and the bargin rockers can let go pretty fast. I'm partial to the Comp "pro magnum" cast alloy steel rockers for a moderate build but a "better" grade aluminum rocker would work fine. For the ignition, the factory setup will light the fire just fine. The drawback is QC on the repop ignition boxes isn't so good. If you go that route, carry a spare. Overall, MSD is more reliable and multi strike sparks do help at idle and low RPM.
Re: Building a 440 stroker - Help! [Re: ahy] #1340845
11/25/12 10:42 AM
11/25/12 10:42 AM
Central NC
gch Offline
gch  Offline
Central NC
Try one of the rev n ator boxes one of our members came up with.Stock chrysler hookup and a rev limiter.
Your money-you pick the parts.
TTi=yes
800 carb=yes(do be prepared to re tune it)
rockers=the best you can afford(don't skimp here)
The sd intake is a good choice for hood clearance and will make tons of torque/power.Be careful not to overcam it if you care about driveability.
Re: Building a 440 stroker - Help! [Re: gch] #1340846
11/25/12 10:53 AM
11/25/12 10:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
We still don't know your performance goals/objectives. No sense in spending thousands on something that will never see the track. How is the rest of the car set-up? Stall, gear.. Again no need to build some high dollar 600+hp engine if all you have/want are a 2800 convert and 3.23 gears...
Re: Building a 440 stroker - Help! [Re: Mr.Yuck] #1340847
11/25/12 11:35 AM
11/25/12 11:35 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
...Again no need to build some high dollar 600+hp engine if all you have/want are a 2800 convert and 3.23 gears...
I take offense to that. Oh, sorry, that does not apply to me, I have an 1800 stall.
Re: Building a 440 stroker - Help! [Re: Mr.Yuck] #1340848
11/25/12 11:57 AM
11/25/12 11:57 AM
Staten Island, NY
Chrisn68 Offline OP
Chrisn68  Offline OP
Staten Island, NY
Hi All,
THANK YOU for the multiple responses! As for performance objectives, I'm looking for an able street cruiser with perhaps an occasional trip to the track for fun, nothing serious. The car has an 18-spline 4 speed and 3.91 gears in an 8-3/4, with a high quality drive shaft. It has Harland Sharp roller rockers and shafts, so while I know there are differing opinions about HS, I didn't skimp in that department.
Based on the feedback you guys are giving, I'm going to go with the MP box for now, stick with my 800cfm carb, and keep my TTI setup. As you said, I can always swap these things later, but for now, I'd like to get it up and running.
I like the suggestions for the intake, which I will bring up with the builder.
Still open to other suggestions/feedback/questions, and I'm sure I'll have more questions as I go along, so thanks again for all the help!
Re: Building a 440 stroker - Help! [Re: Chrisn68] #1340849
11/25/12 12:57 PM
11/25/12 12:57 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
i'm not one to jump into a project blind,i've also been planning a stroker and asked 400 million questions on here and other mopar sites and this is what i came up with:
-compu-flow short block,fully assembled,balanced and top quality part(from what i'm being told the 512 is the way to go)compu-flow 493 is $3600,local shops can't touch this price range
-edelbrock rpm or super stealth cnc'ed
-keeping my m1 and 1-3/4 headers flowing through 3" exhaust
-keepnig my 850 holley
-3:55
-2800 tci stall
-shift kit
-lunatic hydraulic 60303
619hp estimated
500hp is a mild stroker,your builder is spending extra cash for no reason
Re: Building a 440 stroker - Help! [Re: Chrisn68] #1340850
11/25/12 01:03 PM
11/25/12 01:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'd run the Indy dual plane and upgrade the carb later. I'd opt to weld on a 3 1/2" collector on the TTI's because that's 90% of the advantage of the larger tube headers with a heavy automatic combo. Heads I would run ported Eddies like Jeff at Modern has with the 2.19 intake that really kick up the mid lift flows. Cam and converter depend how you gear and want to drive the car but the top end And exhaust I outlined for you can make an EZ 630 + with the right cam and bigger carb on a precision machined 10.75:1 511 shortblock with more broad wall to wall torque than street tires can possibly apply. Bigger cam more gear and your over 650. If it were me though I'd opt for a true max wedge head like the EZ-1 and max wedge port the Indy 2D and you've got true 675+ hp potential with no downside, the 906 port opening is already small for 440 cubes but they still do great in a moderate RPM street strip bruiser.
WIZE
In Car:
Re: Building a 440 stroker - Help! [Re: BSB67] #1340851
11/25/12 02:31 PM
11/25/12 02:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
and just think how much better it would run w/ a real exhaust, some stall and non-highway gears...
Re: Building a 440 stroker - Help! [Re: Streetwize] #1340852
11/25/12 04:40 PM
11/25/12 04:40 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Here's my take on that...........
as mentioned, the 906 port window is too small for a 493+ cubed motor. I got a smokin' hot deal on some ported MW EZ's from the classifieds of this site. Last set of BB heads I'll ever need. If you go big, go the whole package.
As for your driving needs................lots of miles, to me, equates to going realistic on cam duration and valvespring pressure. High spring pressure is hard on valvetrain parts. Going to the track once a year means lots of troublefree street driving would be more desireable. Since you have the HS rockers already, I'd get something they deserve to be matched up with but only a solid tappet with a high zinc additive.
Re: Building a 440 stroker - Help! [Re: CUDA8U] #1340853
11/25/12 05:55 PM
11/25/12 05:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
-3:55
-2800 tci stall
-shift kit
619hp estimated
Sorry to burst your bubble but you're not making 620hp with a lunati 60303 with a 493 and CNC'd RPM or Stealth heads. Those 400 million questions didn't get you that far! I've run that cam, it's pretty tame, you're looking at knocking 100hp off your estimate.
Re: Building a 440 stroker - Help! [Re: DaytonaTurbo] #1340854
11/25/12 07:15 PM
11/25/12 07:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
-3:55
-2800 tci stall
-shift kit
619hp estimated
I have to agree,I have had this cam http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=713&sb=2 before and it just plain made awesome power for a hydraulic grind
Gus
64 Plymouth Savoy
Dana 60
