welding a 1969 HEMI block #1340733
11/24/12 07:04 PM
11/24/12 07:04 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
during our race in Le Mans, a sudden drop in fuel pressure caused an extremly lean condition at full throttle, which burnt a hole in one piston and also damaged the top of a cylinder wall, burnig like a passage between two chambers through the head gasket. This took off about 1/8" of block and cylinder head material.
While repairing the head is no big deal, as it is aluminium, welding the 1/8" of cast iron material back on the block is not that easy.
Would you know what type of iron they used to cast the HEMI back in the day?
Re: welding a 1969 HEMI block [Re: docford] #1340734
11/24/12 07:19 PM
11/24/12 07:19 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not sure where it's damaged but can it be sleeved? Or is this on the deck?
Re: welding a 1969 HEMI block [Re: docford] #1340735
11/24/12 07:26 PM
11/24/12 07:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A welding shop with a oven can do it... they will
use high nickle rod when the block is good and warm
then let it slowly cool back in the oven
Re: welding a 1969 HEMI block [Re: docford] #1340736
11/25/12 12:45 AM
11/25/12 12:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've had that happened on a 440 block, call around to the heavy duty Deisel repair shops in your area and get the name and contact information on the welding shop they use to weld cast iron I ended up on my block having the deck surface brazed by a cast iron deisel welding shop then I had two sleeves installed and then had to have the block decked on a wet surface grinder. The head was cast iron welded and I had to find a shop that had a wet grinder to surface the head also, the regular automotive machine shops in SO CA said they wouldn't touch a welded head on thier equiptment because cast iron turns into a really hard material(it would damage the cutters on thier rotary broaches) when welded Good luck, let us know what you do and the shop that does the work for you please
Re: welding a 1969 HEMI block [Re: Cab_Burge] #1340737
11/25/12 01:31 AM
11/25/12 01:31 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
^^^^^^^this, i have a block that was reapiered this way
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: welding a 1969 HEMI block [Re: bigtimeauto] #1340738
11/25/12 01:47 AM
11/25/12 01:47 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My son burnt a head gasket between number 3 and 5 in his small-block with cast iron heads on it a few years ago.I cleaned it up with a grinder, preheated it with a torch and tigged both the head and block with stainless filler. Worked out great.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: welding a 1969 HEMI block [Re: pittsburghracer] #1340739
11/25/12 02:05 AM
11/25/12 02:05 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Is the block O-ringed? I wonder if brazing the deck to make it flush would do the trick since it's not in a high stress area? AFAIK If you have it cast iron welded the entire block will need to be remachined because the heating and cooling process will likely distort everything.
Re: welding a 1969 HEMI block [Re: Bigcube] #1340740
11/25/12 04:56 AM
11/25/12 04:56 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
It is indeed on the deck. The damage is like a crease joining two cylinders
Re: welding a 1969 HEMI block [Re: pittsburghracer] #1340741
11/25/12 10:01 AM
11/25/12 10:01 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
here is a picture of the damaged cylinder bank. the same crease between the same two cylinders was also burned in the cylinder head.
Re: welding a 1969 HEMI block [Re: docford] #1340742
11/25/12 11:46 AM
11/25/12 11:46 AM
PA.
"Little"John
"Little"John
PA.
That looks exactly like my sons did. Simple fix with tig or high nickle stick rod.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: welding a 1969 HEMI block [Re: pittsburghracer] #1340743
11/25/12 11:49 AM
11/25/12 11:49 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
oven, like cab and mr pea body said....
After that, it would not be a abad idea to check all tolerances and machined surface to double check if they havent distorted.
Re: welding a 1969 HEMI block [Re: pittsburghracer] #1340744
11/25/12 12:54 PM
11/25/12 12:54 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Can you give me the number of the nickle rod you used? Previous owner got wild with valve notches and got to close to pushrod holes, trying to find a fix.
Re: welding a 1969 HEMI block [Re: cudaman1969] #1340745
11/25/12 01:06 PM
11/25/12 01:06 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With the new welding materials and methods this is an easy fix.Just make sure the person doing it is experienced.Protect the area near from any weld splatter. We do this type of repair quite often.
Re: welding a 1969 HEMI block [Re: B G Racing] #1340746
11/25/12 02:44 PM
11/25/12 02:44 PM
PA.
"Little"John
"Little"John
PA.
The last two that I repaired I tigged. My stick welding skills are slowly eroding since I retired from Millwright work 3 years ago. In my shop I either grab the mig or tig. Check out this link if you are going with stick. I used a 3/32 rod. Like Bob said protect surrounding areas from splatter. I use fiberglass cloth and a product called kayo-wool. Keep covered to let it cool slowly after the repair is done. Some guys want to make a simple repair into a project.
http://www.messerwelding.com/Product%20PDFs/by%20part/MG%20765.pdf
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: welding a 1969 HEMI block [Re: pittsburghracer] #1340747
11/25/12 04:10 PM
11/25/12 04:10 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There is a new 55 wire for mig welding cast.
Re: welding a 1969 HEMI block [Re: B G Racing] #1340748
11/25/12 04:33 PM
11/25/12 04:33 PM
PA.
"Little"John
"Little"John
PA.
What gas do they use Bob?
These guys would crap if they saw what we did back in 1985 the week the bad tornadoes came thru. I had a guy weld the deck of my 440 and a head between 3-5 and I filed it flat with a file. Was back racing 2 days later.
A man's gotta do what a man gotta do.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: welding a 1969 HEMI block [Re: B G Racing] #1340749
11/25/12 06:45 PM
11/25/12 06:45 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
great! what weld rod do you use ? would you have a reference ?
Re: welding a 1969 HEMI block [Re: pittsburghracer] #1340750
11/25/12 06:51 PM
11/25/12 06:51 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Thanks!
Would you know about the MG200 electrode ? Would it also do the trick and not be as hard to machine later on ?
Re: welding a 1969 HEMI block [Re: docford] #1340751
11/25/12 08:33 PM
11/25/12 08:33 PM
PA.
"Little"John
"Little"John
PA.
Thanks!
I never used that rod. Your best bet is to go to your local welding supplier and ask what they recommend. I actually dug my 765's out to get you the number and they have a phone number on them.
Canada 1-800-663-2800
U.S. 1-800-654-6333
I keep my good rods in my bedroom.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: welding a 1969 HEMI block [Re: pittsburghracer] #1340752
11/25/12 08:55 PM
11/25/12 08:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We like to use 100%Argon.There are a veriaty of rods if you preferr stick welding.What rod depends on the nickle content of the cast iron.What ever method you use peen each weld application as you weld.I don't suggest any novice take on this type of welding you can ruin parts very easy and create a unrepairable mess.
