1.5 or 1.6 HS rockers. which to buy?? #1340029
11/23/12 12:44 PM
11/23/12 12:44 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
getting ready to buy some new rockers for my w2 econo heads stuck between 1.5 and 1.6 not doing anything special except some street strip with the car what would you recommend and in my case does it really matter??
Re: 1.5 or 1.6 HS rockers. which to buy?? [Re: DaKuda] #1340030
11/23/12 03:32 PM
11/23/12 03:32 PM
Delray beach, Florida
P
Performance Only Offline
P
It depends more on the cam profile and the heads and what type of gains your looking for. If it's a mild to medium cam combo flip a coin, either ratio would work just fine for a street/ strip combo.
machine shop owner and engine builder
Re: 1.5 or 1.6 HS rockers. which to buy?? [Re: DaKuda] #1340031
11/23/12 03:42 PM
11/23/12 03:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
1.6 om W2 work great is my
Re: 1.5 or 1.6 HS rockers. which to buy?? [Re: Cab_Burge] #1340032
11/23/12 04:18 PM
11/23/12 04:18 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Go for the better cam and run the 1.6's
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: 1.5 or 1.6 HS rockers. which to buy?? [Re: DaKuda] #1340033
11/23/12 04:26 PM
11/23/12 04:26 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
1.6ers
Re: 1.5 or 1.6 HS rockers. which to buy?? [Re: 66er] #1340034
11/24/12 12:13 PM
11/24/12 12:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If the price it the same I would go with the 1.6's. I use Hughes 1.6 rockers. Ron
