83/4 back brace question? #1339067
11/21/12 03:50 PM
11/21/12 03:50 PM
IL . usa
cjs69mope Offline OP
IL . usa
Was thinking of getting a back brace for my car ,
already have Mosser axles and 4:10 with Detroit locker .
My question is can I weld on the back brace with the whole unit assembled?
Is their any special things I need to do ?
I was going to try and go slow and jump around like you weld a quarter panel would this be Ok?
1969 Dodge Charger 1969 Dodge Superbee
Re: 83/4 back brace question? [Re: cjs69mope] #1339068
11/21/12 03:56 PM
11/21/12 03:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you can do it assembled and yes jump around when
welding(no more than 1" in a spot... you might want
to drain it if its in the car... jump side to side
to keep it cool
Re: 83/4 back brace question? [Re: MR_P_BODY] #1339069
11/21/12 06:29 PM
11/21/12 06:29 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
IMO draining won't be really needed as the oillevel is always lower than where you are welding.
Besides, won't the body of oil help cooling the metal in the center better?
Re: 83/4 back brace question? [Re: BigBlockMopar] #1339070
11/21/12 06:58 PM
11/21/12 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes BUT if he gets it tooo hot it will flash and then
you might have some problems... granted it shouldnt
ever get that hot if done right
