U Joint Question... #133881
10/08/08 02:55 PM
10/08/08 02:55 PM
Nunya CA
CR8CRSHR Offline OP
CR8CRSHR  Offline OP
Nunya CA
Who has the combination 7260/7290 U Joints for sale. The Spicer U Joint I have will not fit into the pinion yoke side when installing the drive shaft. It is a 7290 U Joint. Fits fine to the drive shaft but not the Yoke. I do not have the time nor want to replace the Pinion Yoke with the larger 7290 set up. Thanks
Re: U Joint Question... [Re: CR8CRSHR] #133882
10/08/08 03:03 PM
10/08/08 03:03 PM
P
Paul_Fancsali Offline
P
I just had this problem last week Get a 5-547X u joint and get only the spicer I have the precision made one and a ADVANCE BRAND 7290 brand neither one fit the yoke on the differential correctly I got Dana spicer from a local drive SHAFT SHOP I was just switching pigs when I lost a cap and the trouble began. the other caps U joints o gave me vibration in the drive train. The precision would not fit yoke correctly
Re: U Joint Question... [Re: Paul_Fancsali] #133883
10/08/08 04:19 PM
10/08/08 04:19 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I've used the Precision and they fit fine for me.
1981 Dodge D150 360 auto
