Voltage Bleed Through Dash Turn Indicator-FIXED #1338777
11/21/12 12:42 AM
11/21/12 12:42 AM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
1965 Coronet:
My Right Dash Turn indicator bulb lightly pulses at all times. It does not flash in sequence when actuated but still just pulses.
The Left Side is fine.
The body front and rear Turns work fine when actuated.
Where should I look for the voltage bleed through?
Will I find continuity between flasher and Right Turn in switch.
Bad Circuit board possibility
Re: Voltage Bleed Through Dash Turn Indicator [Re: 440PURSUIT] #1338778
11/21/12 01:26 AM
11/21/12 01:26 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Probably the circuit board is open on the ground to that lamp socket...
Re: Voltage Bleed Through Dash Turn Indicator [Re: 440PURSUIT] #1338779
11/21/12 08:45 AM
11/21/12 08:45 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Bad ground on the turn signal. Probably the front one.
Those ground through the lamp housing IIRC.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Voltage Bleed Through Dash Turn Indicator [Re: 471Magnum] #1338780
11/21/12 10:06 AM
11/21/12 10:06 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
the pulsing is from the voltage reg. for the gauges. the ground from the dash frame to the gauge panel is loose/dirty. I always add a 14 gauge wire from the back of the gauges steel frame to the dash of the steel frame on the car for a good ground.
Re: Voltage Bleed Through Dash Turn Indicator [Re: 71_deputy] #1338781
11/21/12 12:32 PM
11/21/12 12:32 PM
DC, MD Suburbs
DC, MD Suburbs
Gonna get into it shortly....Thanks for leads
Re: Voltage Bleed Through Dash Turn Indicator [Re: 471Magnum] #1338782
11/21/12 04:00 PM
11/21/12 04:00 PM
Indiana
O
Osyman Offline
Osyman  Offline
O
Indiana
Ive had a similar situation but the problem was the rear light ground.
Re: Voltage Bleed Through Dash Turn Indicator [Re: Osyman] #1338783
11/21/12 09:31 PM
11/21/12 09:31 PM
DC, MD Suburbs
DC, MD Suburbs
Front Turn Signal Socket was crusty but Grounded Fine. I did change the light bulbs while cleaning the sockets.
No Improvement
Checked rear taillight ground . it was good.
No Improvement
Pulled the Dash-Found capacitor not hooked up.
Reconneted
No improvement.
Installed a gound wire from Dash frame to chassis 14ga. No improvement.
Connected Dash ground to battery, No improvement.
I have dash out and will test circuit board. Some of it looks compromised.
Power lead to Ammeter light foil looks broken but away from Turn indicator.
Anyone got a circuit boeard for a 65 Coronet?
Saw a new one on EBAY for $185...NOT.
Re: Voltage Bleed Through Dash Turn Indicator [Re: 440PURSUIT] #1338784
11/21/12 10:23 PM
11/21/12 10:23 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Sure sounds like a bad ground somewhere (maybe ground broke on your circuit board)... after all these 40-50 years of rockin and rollin (and rustin), ground connections come loose, corrode, then the weird electrical shows start to happen (electrons in search of a ground, any ground).
Re: Voltage Bleed Through Dash Turn Indicator [Re: GO_Fish] #1338785
11/21/12 10:26 PM
11/21/12 10:26 PM
New State
kidmopar Offline
kidmopar  Offline
New State
"Gonna get into it shortly....Thanks for leads" { SHORT - LY ? } { LEADS ? } Ha! Ha!
Re: Voltage Bleed Through Dash Turn Indicator-FIXED [Re: 440PURSUIT] #1338786
11/21/12 10:30 PM
11/21/12 10:30 PM
DC, MD Suburbs
DC, MD Suburbs
Circuit Board foil was split.
The Voltage limiters ground was on a shared circuit with the Right Turn Ground and the Ammeter Bulb Ground. Didnt connect through to the board screw that secures it to dash frame. (Upper right) Soldered a bridge and all works again.
Would like a replacement circuit board for peace fo mine.....
Re: Voltage Bleed Through Dash Turn Indicator [Re: Osyman] #1338787
11/21/12 11:19 PM
11/21/12 11:19 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Voltage Bleed Through Dash Turn Indicator [Re: 1_WILD_RT] #1338788
11/21/12 11:47 PM
11/21/12 11:47 PM
DC, MD Suburbs
DC, MD Suburbs
Heading to FL for the Turkey Rod Run and to move some project parts. Maybe will find one there. A lot of Chevy and Ford stuff though to weed through.
Re: Voltage Bleed Through Dash Turn Indicator-FIXED [Re: 440PURSUIT] #1338789
11/22/12 12:06 AM
11/22/12 12:06 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Awesome work detective!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
