Page 2 of 4 1 2 3 4
Re: 360 testing begins,.... [Re: Dunnuck Racing] #1338673
11/27/12 03:25 PM
11/27/12 03:25 PM
Az
Crizila Offline
Crizila  Offline
Az
Since I have already seen windage problems on this engine,I have no doubts we can see results on the dyno. The problem will only be worse at the track.
Most testing that ever shows improvement on the dyno ends up tested at the track later. But who is going to pull their pan and swap trays for back to back track testing on the same day?
Keith
I don't even like changing jets at the track.
Fastest 300
Re: 360 testing begins,.... [Re: Crizila] #1338674
11/27/12 05:54 PM
11/27/12 05:54 PM
Marion,Indiana
Seth_Jones Offline
Seth_Jones  Offline
Marion,Indiana
So as a rule does everybody at leat run the factory windage tray?
Re: 360 testing begins,.... [Re: Seth_Jones] #1338675
11/27/12 06:31 PM
11/27/12 06:31 PM
Washington
skrews Offline
skrews  Offline
Washington
always wanted to try adding a few rows of scraping louvers to a stock tray, sorta like the Milodon tray
Re: 360 testing begins,.... [Re: Dunnuck Racing] #1338676
11/27/12 10:59 PM
11/27/12 10:59 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
A few years ago when I built the current motor the concensus was to run no tray but a deep 8 qt. pan with only 5 qts in it. I would like to see that tested.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: 360 testing begins,.... [Re: fasteddie] #1338677
11/28/12 04:32 AM
11/28/12 04:32 AM
SoCal
Brian Hafliger Offline
SoCal
Exactly...most common problem is overfilling a pan.
First you have to pour the pan and measure how much water it will hold up to the top of the sump. Then add 1Qt for the engine system and filter and 1/2Qt to keep the level consistent while running.
Most guys who run a 7Qt pan end up with 8Qts of oil in the engine and nothing will hurt power and bearings quicker!!
Windage trays that are bolted to the main caps and not in the pan hold too much oil too close to the crank allowing the crankshaft to pull the oil back up on it instead of allowing it to flow into the sump.
So if this happens on the dyno, you can bet it's gonna happen much worse on a drag strip!
Brian
Brian Hafliger
Re: 360 testing begins,.... [Re: Brian Hafliger] #1338678
12/03/12 02:42 PM
12/03/12 02:42 PM
dogdays Offline
dogdays  Offline
Mu Mercedes 2.8 six has a cast aluminum oil pan with scraper fingers cast into the bottom of the pan. They also are turned to direct the scraped-off oil into the sump. This is a short stroke engine and there must have been a reason they went to all the trouble...
R.
Re: 360 testing begins,.... [Re: dogdays] #1338679
12/16/12 10:59 PM
12/16/12 10:59 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
anything new to report?
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: 360 testing begins,.... [Re: aspenrt360] #1338680
12/16/12 11:10 PM
12/16/12 11:10 PM
Northern Indiana
Dunnuck Racing Offline OP
Northern Indiana
Actually,quite a few things.
I have been testing on this engine at least 3 or 4 days a week testing multiple things. I need to go in for a total shoulder replacement surgery in a couple weeks. My goal is to get all my testing done beforehand so I can write a couple articles and update you guys while I recover.
I will tell you now that it's at 365 hp and 402 lbs-ft with a cam and intake change.
The oil testing showed small gains with every drop in viscosity but had minimal oil pressure drop even down to 5-20.
Ill try to update things a little better when I can.
Keith
Re: 360 testing begins,.... [Re: Dunnuck Racing] #1338681
12/17/12 04:24 PM
12/17/12 04:24 PM
aspenrt360 Offline
aspenrt360  Offline
thanks a lot for the reply i am going to follow this thread it looks to be interesting.
good luck with your shoulder!
Re: 360 testing begins,.... [Re: Dunnuck Racing] #1338682
12/17/12 04:42 PM
12/17/12 04:42 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Good luck with the Surgery, Keith!
Oil windage to me seems a lot less like a power adder compared to years past when oil was 40 and 50 weight, even todays race oils are a lot thinner and if you keep the foaming down it seems harder to find the measurable gains we used to see in decades past. Not saying it's not worth persuing but the big WOW type gains (or loss reductions) seem harder to come by. Surfactants have come a long way...all the way down the driveline too.
I'd like to find somebody to deepen and baffle a 318 truck pan for me and extand the pick-up the equal amount, since I can run one on my bracket toy, the advantages of a rear sump seem like a slam-dunk for drag racing.
WIZE
In Car:
Re: 360 testing begins,.... [Re: Streetwize] #1338683
12/17/12 04:58 PM
12/17/12 04:58 PM
P
Paul_Fancsali Offline
P
Just a thought.The 15wt 40wt being a diesel base oil were not really intended for higher RPM and possibility of foaming. Lesson learned by me I will use any oil depending on temp and weather conditions, but curious how well it pulls with 5-20 or the 5-30. Valvoline makes a 10wt 30wt racing oil that seems to do the trick My 10 cents
Re: 360 testing begins,.... [Re: Paul_Fancsali] #1338684
12/17/12 07:03 PM
12/17/12 07:03 PM
Renton Washington
Triple Threat Offline
Renton Washington
Just a thought.The 15wt 40wt being a diesel base oil were not really intended for higher RPM and possibility of foaming. =
I know a guy with a 900" Sonny's engine. The car goes well into the 6's. They told him to run Rotella in it, so he does.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 360 testing begins,.... [Re: Streetwize] #1338685
12/18/12 10:12 AM
12/18/12 10:12 AM
Locomotion Offline
Locomotion  Offline
Milodon has a deep, rear sump truck pan for 318/340 applications.
Milodon 30980 318 truck pan
I'm sure there are others available if the Milodon is too deep.
Related to the original thread topic, I've been using 5w-20 Amsoil Dominator synthetic oil with a scraper on my 360 and have been very happy. I've even seen changes in idle speed when switching from thicker conventional oils used for break-in to the 5w-20. From straight 30w or 40w, it was obvious. From 15w-40, I believe it was slight.
Re: 360 testing begins,.... [Re: Locomotion] #1338686
12/18/12 07:27 PM
12/18/12 07:27 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: 360 testing begins,.... [Re: 65signet] #1338687
12/24/12 08:42 PM
12/24/12 08:42 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
What 65 said above...
Re: 360 testing begins,.... [Re: cudadoug] #1338688
12/25/12 01:24 AM
12/25/12 01:24 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Class racers
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 360 testing begins,.... [Re: Paul_Fancsali] #1338689
12/26/12 12:40 AM
12/26/12 12:40 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I'm watching this thread for ideas...
My non-race truck engine has seen 7,000+ rpms all too many times on 15/40 Rotella without any issues ever. No windage tray or scrapers - just the factory Dakota pan. I've often wondered if lighter oil would yield performance benefits - but have been hesitant to change or try a lighter oil since it's been so trouble free.
Re: 360 testing begins,.... [Re: Duner] #1338690
01/15/13 04:37 PM
01/15/13 04:37 PM
Northern Indiana
Northern Indiana
Lets see if these attachments will show up,.......
Re: 360 testing begins,.... [Re: Dunnuck Racing] #1338691
01/15/13 04:40 PM
01/15/13 04:40 PM
Northern Indiana
Northern Indiana
Last one was horsepower here is torque,.....
Re: 360 testing begins,.... [Re: Dunnuck Racing] #1338692
01/15/13 04:43 PM
01/15/13 04:43 PM
Northern Indiana
Northern Indiana
In graph form,sorry the pictures aren't the best. I'm a one armed photographer for a while yet,.......
Page 2 of 4 1 2 3 4
