New Best 60Ft. #1338387
11/20/12 02:42 AM
11/20/12 02:42 AM
Bloomingdale , OH
super451b Offline OP
Bloomingdale , OH
Last time out for this year , finally got to do a little testing at Thompson Raceway Park and came away with a new best 60 Ft. Came close to the best ET and mph but couldn't beat them. The old best 60 was 1.40 . Made a few changes in the rear shock settings and netted a new best of 1.370 . The old mark was footbraking and the new was with a T-brake.Best ET and mph for the day was 10.19 @ 130.63 . After having a trouble filled year , it was nice to end it on a good note !
Re: New Best 60Ft. [Re: super451b] #1338388
11/20/12 08:30 AM
11/20/12 08:30 AM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Way to go Wade. You really have that big car moving. See you next year.
Butch
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: New Best 60Ft. [Re: super451b] #1338389
11/20/12 12:26 PM
11/20/12 12:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That's great for a big car!
Re: New Best 60Ft. [Re: super451b] #1338390
11/20/12 12:32 PM
11/20/12 12:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I may have asked you this via PM a long time ago, but I'd like to know more details of your combination. I'm hoping my Challenger can run times comparable to yours when it comes back out and knowing how yours is set up vs. mine could give me some ideas of where I may need some additional work...
Re: New Best 60Ft. [Re: BradH] #1338391
11/20/12 12:42 PM
11/20/12 12:42 PM
tboomer Offline
tboomer  Offline
That is a great 60'! I would like to hear more about the car,too!
Re: New Best 60Ft. [Re: tboomer] #1338392
11/20/12 10:45 PM
11/20/12 10:45 PM
Bloomingdale , OH
Bloomingdale , OH
Thanks Guys. The engine is a 451 lowdeck 11.2:1 , 440 source crank and rods (6.385), JE flat tops, Comp 308R solid roller in at 106 ICL ,HS 1.6 rockers,440EZ heads that I hand ported and opened to max wedge, Indy 400-2 intake with a 2" spacer/adapter , 1050 Dominator , Hooker 2" Super Comps
727 Torqueflite, TA J converter (5400) , Tranzact ultimate brake , Dana 60 4.56 , Hoosier 29.5 x 11.5W, Competition Engineering Ladder Link bars, Strange single adjustables with 150# springs,
Front suspension is stock sm. blk. t-bars and some old 3 way adjustable summit shocks on the 90/10 setting.
Heres a picture from that pass:
Re: New Best 60Ft. [Re: super451b] #1338393
11/20/12 11:54 PM
11/20/12 11:54 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
way to go buddy! beep
Re: New Best 60Ft. [Re: super451b] #1338394
11/21/12 12:27 AM
11/21/12 12:27 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
You better slow down alittle, that's too fast for a BIG car. The new transmission must have helped.
If you like drag racing, support your local track.
Re: New Best 60Ft. [Re: CHAPPER] #1338395
11/21/12 12:37 AM
11/21/12 12:37 AM
Bloomingdale , OH
Bloomingdale , OH
Fred , you could be right, about the tranny ,that is . I'm launching the car 1000 rpm higher , with the brake , than I was footbraking it. I wanted to try going up on the launch rpm more but ran out of time .
Re: New Best 60Ft. [Re: super451b] #1338396
11/21/12 01:02 AM
11/21/12 01:02 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That car works very good!
Re: New Best 60Ft. [Re: Dodgem] #1338397
11/21/12 01:38 AM
11/21/12 01:38 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Love the car Wade...especially in white with the black trim..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: New Best 60Ft. [Re: super451b] #1338398
11/21/12 01:49 AM
11/21/12 01:49 AM
BradH Offline
BradH  Offline
... Comp 308R solid roller in at 106 ICL ,HS 1.6 rockers
I'm not familiar w/ that particular cam. Can you give more details about it?
That whole combination you outlined just seems to WORK.
Re: New Best 60Ft. [Re: BradH] #1338399
11/21/12 02:58 AM
11/21/12 02:58 AM
Bloomingdale , OH
Bloomingdale , OH
Brad its just a shelf grind comp solid roller:
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=739&sb=0
I have it installed at 106 intake center line and use Harland Sharp 1.6 rockers on the intake and exhaust. It really does work well !
Re: New Best 60Ft. [Re: super451b] #1338400
11/21/12 07:37 AM
11/21/12 07:37 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Congrats on the 60ft. That's good going for a big car like that.
With a 29.5 tyre and a 4.56 gear, you must be turning in excess of 7000 rpm through the line.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: New Best 60Ft. [Re: super451b] #1338401
11/21/12 08:11 AM
11/21/12 08:11 AM
gregsdart Online content
gregsdart  Online Content
Making some steam and putting it to the ground!
Re: New Best 60Ft. [Re: super451b] #1338402
11/21/12 11:55 AM
11/21/12 11:55 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Damn good 60ft. for than land barge.............. No dissrespect..........What shock changes did you make?
Re: New Best 60Ft. [Re: deaks] #1338403
11/21/12 02:19 PM
11/21/12 02:19 PM
Bloomingdale , OH
Bloomingdale , OH
Mick , it's turning just a hair over 7000 at the stripe. The 29.5 W series tire actually has a diameter closer to 31 inches.
Dom, I made a base pass first , then went 1 click stiffer on both sides and it slowed the 60 . then went back to the base setting and the 60 came back, then 1 click softer on both sides the 60 was a little better and then went 1 click softer on just the right side . It seemed to like it there. Ended up with the at 3 on the left side and 2 on the right.
Re: New Best 60Ft. [Re: super451b] #1338404
12/11/12 04:43 PM
12/11/12 04:43 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Car looks great! Those are some really nice pics! Glad you ended it on a high note this year!!
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: New Best 60Ft. [Re: mopar400] #1338405
12/11/12 04:47 PM
12/11/12 04:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on an awesome new best 60. Thats moving in that big car. What does she weigh ? Ron
Re: New Best 60Ft. [Re: 383man] #1338406
12/11/12 08:25 PM
12/11/12 08:25 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
3515# Ron
It's in his sig
Mick
best 60ft 1.36
