Re: AJ and JEGS team up
[Re: gofish]
#1337876
11/19/12 04:29 PM
11/19/12 04:29 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: Jeffaary]
#1337883
11/19/12 05:16 PM
11/19/12 05:16 PM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
It says Vincent Nobile will continue to use Johnson & Johnson engines. No mention of V. Gaines...
V. has his own engine program.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: gofish]
#1337885
11/19/12 05:40 PM
11/19/12 05:40 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
As long as Nobile doesn't get the short end of the stick,this should put Mopar 123 in the standings next year.
[Re: gofish]
#1337889
11/19/12 06:30 PM
11/19/12 06:30 PM
Posts: 2,110 toledo, ohio
plasticfantastic
toledo, ohio
Now if they would get a car better looking than the Avenger!
Danny
I think the Avenger is going to look really nice with the #1 on the side.
[Re: OhioMopar]
#1337892
11/19/12 06:43 PM
11/19/12 06:43 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Maybe we can get back to MoPar 1 and 2 every week and WJ complaining all the time?
Anderson has assumed the role of WJ....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1337893
11/19/12 06:49 PM
11/19/12 06:49 PM
BradH
