High Volume vs Standard Volume Oil Pump #1337680
11/19/12 11:46 AM
11/19/12 11:46 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright guys, so I initially bought a high volume pump because I was planning to run an 8 quart pan. I decided I didn't want to deal with ground clearance issues, and bought a repop 71 Hemi 6 quart pan. I bought a standard volume pump at the same time, figuring I don't want to risk running the pan dry and I'd use the HV pump on something else. Now I'm starting to rethink. What thinks Moparts?
This is a street car with .0027 clearance on the mains and .0025 on the rods. It will see some strip time and is driven hard on the street.
Re: High Volume vs Standard Volume Oil Pump [Re: GTX MATT] #1337681
11/19/12 12:30 PM
11/19/12 12:30 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I would stay with the hi-volume pump,if you have an issue with low sump volume just add an extra quart.
Re: High Volume vs Standard Volume Oil Pump [Re: GTX MATT] #1337682
11/19/12 01:50 PM
11/19/12 01:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
personally i think the HV pump sucking the pan dry is a wives tale. if both the HV and standard pump carry the same oil pressure throughout the operating range then the exact same amount of oil is being pumped through the engine the only difference is the HV pump is internally recirculating more oil.
the best pump for the application is the smallest pump that will deliver the desired oil pressure under the expected operating conditions. anything else is a waste of HP and unnecessary load on the drive system
Re: High Volume vs Standard Volume Oil Pump [Re: jamesc] #1337683
11/19/12 01:55 PM
11/19/12 01:55 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Also want to throw in this engine has aluminum heads
Re: High Volume vs Standard Volume Oil Pump [Re: jamesc] #1337684
11/19/12 03:03 PM
11/19/12 03:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
OP, my 518 pump gas stroker has more bearing clearances than yours as well as oiling the rockers full time, I use the same oil pan I use 5W20WT Valvoline non synthetic, I have to keep the oil level above the add mark at the drag strip, if I don't the oil pressure will drop off when I let off. I cross the finish line between 6500 and 7000 RPM depending on which rear tires are on the car, it runs 134.+ MPH I did cut the bypass spring down so I have right at 65 lbs of pressure at 6500 RPM with hot oil on the engine dyno, I think it was 1 1/2 coils
Re: High Volume vs Standard Volume Oil Pump [Re: jamesc] #1337685
11/19/12 03:25 PM
11/19/12 03:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Cannot agree more, altho I have not taken time to mess with mine and just run a HV pump.
Re: High Volume vs Standard Volume Oil Pump [Re: dartman366] #1337686
11/19/12 03:57 PM
11/19/12 03:57 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I run a blueprinted and hand ported stock volume pump on any of my big blocks that turn up to ~7200 rpm. You'd be suprised what they'll keep up with by just opening up the inlet to 1/2" and chamfering that severe 90 degree turn in the pump head itself
Both the high-volume and standard pumps seem to have the same inlet/outlet "head" casting; I for one never saw the point/value of opening up the block pick-up to 1/2" and leaving the restrictive 3/8" id head on the pump
if you make it easy to supply the oil to the pump and provide it relatively unrestricted to the mains, you make it a lot easier for the system to do its job.
The interesting thing about oiling systems is since you have a series of controlled orifice "bleeds" ; so as you bleed pass each journal you have proportionally less oil pressure available for the next one in the path. Therefore the 'easiest' (and arguably most effective) ways to help the system "circuit" is to reduce as many upstream bottlenecks as you can. The pump head is the first place I go toward improving the system.
WIZE
In Car:
Re: High Volume vs Standard Volume Oil Pump [Re: GTX MATT] #1337687
11/19/12 05:49 PM
11/19/12 05:49 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
There is one more benefit whit a stock oil pump and that is that you save the drive gear if you use a roller cam as there has to be a bronze gear and the std pump will give you the oil you need so it´s a win win deal and more hp to the rear tires !!!
Re: High Volume vs Standard Volume Oil Pump [Re: Streetwize] #1337688
11/19/12 09:16 PM
11/19/12 09:16 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
with 'Wise. I would definitely enlarge the suction side (pump head) of the block to 1/2" (Hemi diameter) and chamfer the 90 degree bend to the pump mount. As far as the pump is concerned with, hi-volume is what I'd go with. 6 Quart pan is fine, but and 7-8 quart "kickout-style" pan is a little better. More capacity, ground clearance is good but... it may or may not work for you, depending on your steering linkage clearances and chassis. Check on it. Oil lubricates and HELPS cool also, the more oil capacity, the better.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: High Volume vs Standard Volume Oil Pump [Re: HYPER8oSoNic] #1337689
11/19/12 11:39 PM
11/19/12 11:39 PM
IN
ahy Offline
ahy  Offline
IN
Agree run the smallest pump that will meet your needs. The main benefit of the HV pump is improved hot oil pressure at idle and low RPM. With your clearances, you may need/want the added pressure, especially if the main bearings are full groove. Personally I would (and did) pick the HV pump and Hemi pan combo.
Re: High Volume vs Standard Volume Oil Pump [Re: ahy] #1337690
11/20/12 02:50 AM
11/20/12 02:50 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Thats pretty much what I'm asking, with the motor on the loose side at .0027 and .0025 what kind of oil pressure is the standard volume pump going to make? I'd like to have at least 30-35 lbs at hot idle, 55-65 at cruise/high rpm.
Re: High Volume vs Standard Volume Oil Pump [Re: GTX MATT] #1337691
11/20/12 08:48 AM
11/20/12 08:48 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
There are so many other clearances that matter that we don't talk about so it is hard to say.
I have .0028/.0022, full groove mains, full time unrestricted oiling to the valve gear, hand massaged std. rotor pump, and 5-30 full synthetic oil. Hot, in gear (700 rpm) is about 18-20 psi, neutral (850 rpm) 20-23 psi. It climbs to 50+ with the slightest amount of throttle.
Re: High Volume vs Standard Volume Oil Pump [Re: jamesc] #1337692
11/20/12 10:27 AM
11/20/12 10:27 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I will send you my burnt rod.....Was running 9.5 quarts, and starved one rod.
Re: High Volume vs Standard Volume Oil Pump [Re: Dragula] #1337693
11/20/12 10:37 AM
11/20/12 10:37 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
was it number 6 by any chance?
Joe
Without Data, you’re just another guy with an opinion.
Re: High Volume vs Standard Volume Oil Pump [Re: sr4440] #1337694
11/20/12 10:42 AM
11/20/12 10:42 AM
Dragula Offline
Dragula  Offline
It was #3 or #4...
Re: High Volume vs Standard Volume Oil Pump [Re: sr4440] #1337695
11/20/12 10:52 AM
11/20/12 10:52 AM
Lehigh Acres, Florida
rickstershemi Offline
my 408" stock 360 block, HV Melling Pump, 90* Adaptor w/Wix 5151R filter, runs 60lbs at idle once everything is up to temp with 10w30 VR1, but will jump past 90* at a moderate rise in rpm on the test stand...?????
Seems to be getting plenty of oil up top...????
Rickster
Re: High Volume vs Standard Volume Oil Pump [Re: Dragula] #1337696
11/20/12 11:32 AM
11/20/12 11:32 AM
jamesc Offline
jamesc  Offline
everyone is entitled to their opinion mine is that if you have 2 1/2 gallons of oil in an engine and can't keep things wet there's something else wrong other than the size of the pump, the oil pumps job is pretty simple. if you have that much oil in suspension then the return is inadequate, clearances too loose or some other oil control problem is going on (or a combination).
if you burned something up the HV pump was NOT the cause
what people just don't seem to grasp is that no matter WHAT size pump is on an engine if at any given point in the operating conditions the oil pressure is the same then the flow of oil through the engine is the same...period
if you're at 7000 rpm and have 75# of pressure with a stock pump and 75# with a HV pump then the flow THROUGH the engine is the same.
IF you have 75# with a stock pump and 60# with a HV pump (due to relief spring differences) then the STOCK pump is circulating more oil through the engine.
don't believe me ask a hydraulics engineer
Re: High Volume vs Standard Volume Oil Pump [Re: jamesc] #1337697
11/20/12 11:52 AM
11/20/12 11:52 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
JamesC,
Well yes and no, Gauge pressure doesn't always tell the entire story since there are both series and parallel hydraulic circuits in the motor and the gauge pressure reading locations in the circuit can vary somewhat by the motor. It depends to some degree where the failure is. For example if a #5 rod bearing fails it severely reduces the oil to the rods downstream on the crank from it, but the rods upstream and closer to the pump (though much lower) could still have adequate pressure. Depending on where the sender is on that motor you may see different gauge readings. for example a small block sender is pretty close to the pump as it's off the #5 main while on a big block the sender is off the back of the block (clear on the other side of the crank) while the pump is up front. so Low pressure at idle to me is a bit relative, In line with what Rickster finds on his motor, small blocks always seem to have way better GAUGE idle pressure than big blocks from my experience, I think the location of the sender relative to the pump discharge has a bit to do with it but I may be wrong.
As I said earlier one of the best ways to insure circuit flow is to tackle the pump discharge efficiency since it potentially has a positive effect on everything in the system.
I agree a 9.5 quart system sucking dry and leading to a rod failure seems unusual, a motor autospy can usually determine the cause and effect.
WIZE
In Car:
Re: High Volume vs Standard Volume Oil Pump [Re: Streetwize] #1337698
11/20/12 01:00 PM
11/20/12 01:00 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With our limited experience,the standard non hi-volume pump will not keep up with the demands of a hemi above 6500rpm.We have seen increased bearing wear as well as topend wear.If the pump starves any area and oil passages, cavitation can occurr,air lubes nothing.As we have mentioned time and time again a hemi on a adverage 10 second pass will circulate 10 qurts of oil aprox. 3xs.This is why the need for larger sumps and more elaborate oil systems are critical.Volume is as important or more so as pressure.We have seen the big SS race hemis with hardly any oil pressure at idle and aprox.65# down track survive because of the volume of oil in the sump,accumulaters and a big pump to deliver that volume.That a hemi retains more oil in the top makes a dual line system and large sump critical over 7000rpm. My opinion only.
If the results don't support the theory,find another theory.
Re: High Volume vs Standard Volume Oil Pump [Re: Dragula] #1337699
11/20/12 01:11 PM
11/20/12 01:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You my friend MAY have other problems..........I run 5w30 Mobile-1 and w/6-quarts in an 8-quart pan and a hv pump I never hurt anything and my bearings looked real good after 7 years of street/strip thrashing...........
