Re: Gen3 question 6.1
[Re: Moparmal]
#1337296
11/26/12 05:43 PM
11/26/12 05:43 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Plus I think I read that once duration gets too high, the stock Gen III engines run into piston to valve clearance issues, someone correct me if I'm wrong but I think that's an issue as well
Spot on - 228 Intake is about the limit with the 6.1
The Arrington ST3-A runs this intake duration and AJ from that company confirmed to me that P-V was pretty tight but they get away with it.
But back to the duration question - these are Hyd roller profiles...so its apples and oranges comparing to the old LA flat tappet.
This.
[Re: Garry Owen]
#1337298
11/26/12 06:55 PM
11/26/12 06:55 PM
AlexP
Houston, Tx
Alex, are you still in standing with Franks?
On a business level, no. Personally, yes. ![](/ubbthreads/images/graemlins/wink.gif)
I can help you either way.
