Re: Gen3 question 6.1 [Re: Lightning] #1337293
11/22/12 09:25 PM
11/22/12 09:25 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I've got a stupid question about the Gen 3's: How come they don't seem to need the bigger duration like the older engine's do?
better port design....if you have a head that flows 320cfm with good port velocity and strong low lift flow, you don't need nearly as big of a cam as you do if you have a head that flows 220....
2017 Grand Cherokee Overland
Re: Gen3 question 6.1 [Re: Lightning] #1337294
11/22/12 11:53 PM
11/22/12 11:53 PM
Canada
WO23Coronet Online content
WO23Coronet  Online Content
Canada
Plus I think I read that once duration gets too high, the stock Gen III engines run into piston to valve clearance issues, someone correct me if I'm wrong but I think that's an issue as well
Re: Gen3 question 6.1 [Re: WO23Coronet] #1337295
11/24/12 07:47 PM
11/24/12 07:47 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Spot on - 228 Intake is about the limit with the 6.1
The Arrington ST3-A runs this intake duration and AJ from that company confirmed to me that P-V was pretty tight but they get away with it.
But back to the duration question - these are Hyd roller profiles...so its apples and oranges comparing to the old LA flat tappet.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Gen3 question 6.1 [Re: Moparmal] #1337296
11/26/12 05:43 PM
11/26/12 05:43 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
This.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gen3 question 6.1 [Re: AlexP] #1337297
11/26/12 05:55 PM
11/26/12 05:55 PM
Garry Owen Offline OP
Alex, are you still in standing with Franks?
Re: Gen3 question 6.1 [Re: Garry Owen] #1337298
11/26/12 06:55 PM
11/26/12 06:55 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
On a business level, no. Personally, yes.
I can help you either way.
Re: Gen3 question 6.1 [Re: AlexP] #1337299
11/26/12 07:09 PM
11/26/12 07:09 PM
Just comparing cams, I know Fri had some pretty good cams.
So far I've got a couple in mind.
Comp 268
Spartan Max
Arrington st3a
And something comparable in a Fri.
