Re: 4.5" stroke 440?
[Re: 451Mopar]
#1336957
11/18/12 11:27 AM
11/18/12 11:27 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I built one, it was a strong engine. Homeported RPM heads, the 3600 lbs car run 10.4's on street radials and stock chassis, and that was with a PG trans and 3.23 rear gears.
Plynouth VIP '67 TT IC EFI
[Re: 451Mopar]
#1336958
11/18/12 02:48 PM
11/18/12 02:48 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The limiting factor is the block bottom end strength. A 4.5 stroke motor will get you 535 to 541 cubes, more than enough to get into 850 to 900 hp with the right heads. If you plan on running a small port head, then the revs will stay down around 5800 to 6000 rpm and the motor should live a long life. Go with a very good crank if you can, and consider a 2.100 rod bearing size in a very long aluminum rod to make for a light rotating assembly. You could go as long as 7.210 with a 1.24 compression height piston. Basically if you are willing to go custom aluminum rods, then talk to your piston maker first, then build the rods to fit. Or you can just go with a 2.2 h beam that is 7.10 long, but the assembly will be a bit heavier.
[Re: dodgeboy11]
#1336962
11/19/12 03:47 AM
11/19/12 03:47 AM
jyrki
Finalnd, Perkele
External oiling is a must. The one I built was with stock bottom with main studs, no girdle or aluminum caps. It was an Eagle kit with Mahle flat top pistons, the CR was pretty stout despite of removing material from the chambers and pistons where you could. But still it run with our 93 octane. The heads weren't quite ported to the MW size, somewhere around half way, and the engine had huge tq. It was all done at about 5500 rpm, the cam was a custom street roller from Scott Brown with a little over 270 degrees at .050".
