Re: vin numbers 70 barracuda
[Re: Alaskan_TA]
#1336904
11/18/12 03:19 AM
11/18/12 03:19 AM
cudaman440_1
I thought it was 70 model cause its got 70 taillights. But it dose have 71 fenders,valvance,2 headlights on the leftside No headlights on the right. I HOPE ITS A 71
[Re: MMC Detroit]
#1336907
11/18/12 11:51 AM
11/18/12 11:51 AM
cudaman440_1
Where are the parking brake cable support brackets mounted ?
Can you tell me where to start looking for the brackets its sitting outside with flat tires
[Re: Pacnorthcuda]
#1336910
11/18/12 05:08 PM
11/18/12 05:08 PM
cudaman440_1
This going to change my plans i cant cut a 71 for a racecar
You draw that hard of a line tween 70 and 71?
yea i do.it is getting hard to find a 71
[Re: cudaman440_1]
#1336911
11/18/12 05:09 PM
11/18/12 05:09 PM
Posts: 2,304 WI
RestoRick
WI
Inboard side of the rear frame rails, toward the front. 70 will have one bracket on the driver's side, 71 has one on each side. These are the brackets that the rear axle parking brake cables plug in to.
Re: vin numbers 71 barracuda
[Re: cudaman440_1]
#1336918
11/23/12 12:35 PM
11/23/12 12:35 PM
Posts: 1,992 midwest
68427vette
midwest
well i torn the 71 barracuda down today how do kill the rust you cant get to
chemically dip the body, and then use a paint long wand to spray epoxy indise the groves, coves.. go further--drill holes,, then weld them up,, but for a race car,,, no need
[Re: 68427vette]
#1336919
11/27/12 03:04 AM
11/27/12 03:04 AM
cudaman440_1
