Change from column to console shift #1336367
11/17/12 01:35 AM
11/17/12 01:35 AM
Washington
rsusag Offline OP
rsusag  Offline OP
Washington
I have the parts to change from column auto to console shift on my 67 dart. I need to know the distance from some hard point to locate the console. I suppose one could from under the car find the place where the hole should be made. Anyone have some advice? Thanks Ron
Re: Change from column to console shift [Re: rsusag] #1336368
11/17/12 04:13 PM
11/17/12 04:13 PM
NJ
rth Offline
rth  Offline
NJ
With the rug out of the way, you will see the circle on the drivers side of tunnel. Thats where the boot mounts for the shaft that attaches to bracket on trans. Get your shifter and brackets mounted first.
Re: Change from column to console shift [Re: rsusag] #1336369
11/17/12 06:03 PM
11/17/12 06:03 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
IIRC when I did my 69 Dart the dimples were in the floor where the console brackets were to be tack welded. I def agree with the above post, we located the shifter first, hard to mess up once it's installed.
Here are a few pics I found of the install.
1972 Road Runner
1988 Shelby CSX-T
Re: Change from column to console shift [Re: racerx20] #1336370
11/17/12 06:19 PM
11/17/12 06:19 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I did the same in my '73 Dart, work your way up from the transmission.
Connect the linkage on the tranny first, then inside temporarly position the shifter with brackets and see if it goes through all the gears properly, then weld the brackets in place.
