Re: 340 install, whats the best ignition system
[Re: Dennispsalm91]
#133618
10/07/08 08:29 PM
10/07/08 08:29 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
There reallly is no advantage in performance for ow buck to high $$ except bells and whistles if the system is performing the way it is supposed to and not faulty. I would and do run with the oem type. If something goes south the parts are no farther than your nearest corner parts house. I did update? to a Crane system with MSD distributor in the race car. What did I gain?? ease of setting the advance. which is no big deal because once set it is set and don't change. A rev limiter was also gained. Again big price for that. As for performance 0 gain. ![](/ubbthreads/images/graemlins/shruggy.gif) 350 + bucks needlessly spent.
[Re: cogen80]
#133620
10/07/08 08:42 PM
10/07/08 08:42 PM
RapidRobert
I would go with a FBO ecu/coil & a quality dist that the curve can be adjusted externally. EDIT I would give Don @ FBO a call & pick his brain, very informative for the slight addition to your ph bill.
[Re: Dennispsalm91]
#133622
10/07/08 11:03 PM
10/07/08 11:03 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
there are couple of threads talking about that, and apparently for the investment, go for MSD ign is not worth specially for the use you will have. MP will be good enough and MSD or MP blaster coil ( they are the same )
