66 Belv - Ignition #1335868
11/15/12 08:48 PM
11/15/12 08:48 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
On a new to me ‘66 Belvedere, when I turn the ignition to the on position I get a very noticeable, load, whirring sound – after I turn the key to start and engine has started, it is still there in the background – does anybody know what causes that sound? – is it normal for ’66?
Re: 66 Belv - Ignition [Re: edl] #1335869
11/15/12 10:08 PM
11/15/12 10:08 PM
scratchnfotraction Offline
could it be the heater fan motor when key is on?
check that with someone switching the key.
Re: 66 Belv - Ignition [Re: scratchnfotraction] #1335870
11/15/12 11:52 PM
11/15/12 11:52 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
good thought...will look into it and circle back
Re: 66 Belv - Ignition [Re: scratchnfotraction] #1335871
11/15/12 11:52 PM
11/15/12 11:52 PM
IOWA
DOMINATOR5D Offline
DOMINATOR5D  Offline
IOWA
Maybe it has an electric fuel pump, mine does and you can hear it run. Good luck!
Re: 66 Belv - Ignition [Re: DOMINATOR5D] #1335872
11/15/12 11:57 PM
11/15/12 11:57 PM
Northeast
edl Offline OP
edl  Offline OP
Northeast
the previous owner did install an electric fuel pump...but it is in the back of the car...maybe i can hear it all the way up front? - i'll look into that too - good thought!
