How do I tell what year of 727 I have? #133566
10/07/08 06:41 PM
10/07/08 06:41 PM
Grand Rapids, MI
11secondC Offline OP
Grand Rapids, MI
Need to know if I have a '62-66 piece or a '67 and newer. I blew the reverse/low servo out again and now I'm looking at using one of the billet replacement upgrade pieces, but they are different between the early and later versions.
When I had the trans built, I dropped off 3 cores, 1 early and 2 late, but never asked as to which he ended up using, and that was almost 10 years ago. Any quick way short of pulling it down to check?
Re: How do I tell what year of 727 I have? [Re: 11secondC] #133567
10/07/08 07:56 PM
10/07/08 07:56 PM
Look on the side of the extension housing(I forget which side) & see if there's a 2 digit # ie 77. I am into 904's & alot of them are numbered that way & your 727 might be also.
Re: How do I tell what year of 727 I have? [Re: 11secondC] #133568
10/07/08 09:00 PM
10/07/08 09:00 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Post the 7 digit number next to the neutral safety switch. I have a table right on my desk that has the list of #s. Ill let you know.
