Help... 46RE Transmission - Need an odd part #133562
10/07/08 06:02 PM
10/07/08 06:02 PM
Virginia
mopars4life Offline OP
Virginia
I am putting together a 46re for my 99 ram 1500. The metal check ball that goes against the rooster comb in the valve body (which is under spring pressure)went mia (even though I used a zip tie-it launched). I need this before I can go any further. Does the aftermarket sell those or are they the same as a 727 trans? I would be willing to buy a whole valve body if it was cheap enough and came with this. I know rebuild kits don't have them and I have a feeling that the dealer doesn't either. I was going to check with some local trans shops too. Any help and advice is appreciated.
Re: Help... 46RE Transmission - Need an odd part [Re: mopars4life] #133563
10/07/08 07:09 PM
10/07/08 07:09 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
its the same as a 727 I believe its a 5/16 ball but I am not at work so not positive but you may find one at a hardware store
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Help... 46RE Transmission - Need an odd part [Re: dusturbd340W5] #133564
10/07/08 08:34 PM
10/07/08 08:34 PM
Virginia
Virginia
Thanks, I used to work at a Trans shop in the mid 90's before these were out but I wasn't'a builder then.
Re: Help... 46RE Transmission - Need an odd part [Re: mopars4life] #133565
10/08/08 02:40 PM
10/08/08 02:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The detent ball is a 11/32".
