Re: How critical is adjusting shock length with lowered car
[Re: PlumCrazyChris]
#1335216
11/14/12 06:44 PM
11/14/12 06:44 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
very - so the shock doesn't bottom out.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: BigBlockMopar]
#1335218
11/15/12 01:53 AM
11/15/12 01:53 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
With blocks under the axle and turned down torsionbars, only the front shocks will see the lower ride height, not the rears.
But if you run less arch rear spring OR the front and/or spring pick up points are moved up then you need shorter shocks.
#1335219
11/15/12 03:09 AM
11/15/12 03:09 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Do you have a small or big-block? The big-block has extra front-end weight, as you know. So, with a lowered body, you could bottom out the shocks under hard cornering AND more likely during hard deceleration (I know first-hand on that!) Talk with QA1 and they should be able to recommend the correct shocks. (I highly suggest for you to consider stiffer torsion bars to help prevent the front from diving and bottoming the shocks... FirmFeel's 1.12 would be very helpful and still not very stiff for the street.)
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Dan@Hotchkis]
#1335221
11/15/12 01:06 PM
11/15/12 01:06 PM
Posts: 102 Round Rock, Tx
PlumCrazyChris
Round Rock, Tx
Great replies guys, I knew this was the place to ask.
I have a Gen III hemi in it, and the rear is lowered with factory aging, a spring relo kit 1" front hanger drop from Dr. Diff.
I have .92 Tbars for now, but have thought of going bigger. It handled fairly well before the motor swap and I figured with the lighter engine, battery relo to the back, frame connectors and lower profile tires (285/40/18 and 255/45/17 KDWs), it would feel much stiffer with the same bars, but I'll wait and see how it feels.
It also has 1.125" front and .75" rear sway bars, factory big disk swap, A500 trans, and a 3.73SG 8 3/4 rear with 11x2" drums from a C body.
I'm hoping it will be a nice street car with occasional trips through the cones. I'm planning on it being my daily driver.
Ive looked at the Qa1 catalog, and they don't seem to have a shock that immediately shouts "I'm the one to order" so I'll take your advice and call them to see what they say.
It sounds like a lot of folks have had problems getting their cars lower with the new thicker bars and the way they are clocked.
I'd rather not have to spend another $400 for drop spindles (not to mention the effort with the swap).
Have y'all had to go with drop spindle with the thicker Tbars?
[Re: BigBlockMopar]
#1335223
11/15/12 06:39 PM
11/15/12 06:39 PM
amxautox
Then take the bumpstops off, then see if the shock bottoms out. If not, then don't worry about it, and put the bumpstops back on. After all the rubber bumpstops squish down somewhat.
Depends on how you lower the rear. Flater leaf spring, adjustable/different spring perches, or spacer blocks between the spring and axle tube - which doesn't effect the shock length as the shock plate will be in the same location relavent to the upper frame/shock mount.
And you also have to allow for any additional movement that the rubber bushings in the lower control arm to frame mount, IF they are rubber. Even poly will have a slight movement under extreme pressure of hard cornering and dips and bumps at speed.
Tom
author unknown
#1335225
11/16/12 02:33 AM
11/16/12 02:33 AM
PlumCrazyChris
Round Rock, Tx
Anybody have experience with this issue?
#1335227
11/16/12 11:58 PM
11/16/12 11:58 PM
Posts: 31,046 Oregon
AndyF
Yes, it is a problem if you buy torsion bars from vendors who don't know what they are doing. If you buy torsion bars from Firm Feel then you won't have that problem. There are a couple of vendors who sell torsion bars that do not fit because the clocking is wrong.
