I just bought a 81 Ramcharger with a 318. It runs ok but dies when it's put in gear. It has a Holley 2280 and I noticed the idle solenoid has the wires cut on it. I found a single wire, black with an orange stripe with a small plug but don't know if that's where it should be wired to. There's another cut coming off the bracket. A ground? Does anyone have a picture of one hooked up correctly or a link to a diagram?
