727 question for trans specialists.. #1334778
11/13/12 02:51 PM
11/13/12 02:51 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
When the motor let go last year and since the trans was out of the car, I sent it in for an inspection only trying to catch any problems before they happen.. Well the trans guy comes back and says it needs this.. and it needs that.. and we ended up getting a complete freshen up on the trans..
One year later, we put the trans in and there is no fluid circulating... the TC level is the same and there is no fluid in the cooler and we have no forward or backwards gears.. So the trans came out and is now at the trans shop for inspection..
When we dropped it off, the one thing the trans guy says is kinda sticking with me... "It could be the pressure regulator"... except the trans was working 100% fine when it was last pulled and having the inspection done was only a precaution..
Since I know very little about how a trans works, what are some of the things I should be prepared for when I stop in later today to check on its progress..
Thanks in advance..
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334779
11/13/12 03:07 PM
11/13/12 03:07 PM
fullmetaljacket Offline
Though we are on the right coast, you can ask my friend who's father is probably the best Trans guru in the nation.
Curt is his name and Curt Sr. will be the answer guy.
Post me on mail and I'll get you in contact with him.
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334780
11/13/12 03:11 PM
11/13/12 03:11 PM
Guitar Jones Offline
Thanks in advance..
You should be prepared for "We took care of it for you, no charge."
Unless of course the converter wasn't fully seated and you broke the pump gear.
Good luck to you.
Re: 727 question for trans specialists.. [Re: fullmetaljacket] #1334781
11/13/12 03:44 PM
11/13/12 03:44 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
If this situation turns into a big ordeal, I'll ask ya for his number.. but I was trying to pick up some information before I talk with my trans guy...
Thanks anyways
Re: 727 question for trans specialists.. [Re: Guitar Jones] #1334782
11/13/12 03:46 PM
11/13/12 03:46 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Good luck to you.
I probably should have stated that in my first post.. the converter was seated properly and the two tangs on the pump are ok..
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334783
11/13/12 03:57 PM
11/13/12 03:57 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
If it's one thing I've learned.. If it worked fine before.. go back to what was just done.
No iffs or butts about it. Don't let him bs you.
Hope he's a friend..good luck.
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334784
11/13/12 05:52 PM
11/13/12 05:52 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Sounds like the front trans pump was dry from sitting, and then did not pick up the fluid thus no pressure.
Pump rotors need oil or some lube to start working
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334785
11/13/12 07:58 PM
11/13/12 07:58 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
pump should pickup oil if it's lightly oiled or not. maybe he forgot to put the filter on or the spacer if u have a deep pan.
Re: 727 question for trans specialists.. [Re: rickraw] #1334786
11/13/12 08:21 PM
11/13/12 08:21 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
That was my first thought too after I read your converter was seated and no tangs broken on the converter or pump.
Could you hear any buzzing coming from the VB area?
Re: 727 question for trans specialists.. [Re: Max Wedge Savoy] #1334787
11/13/12 10:00 PM
11/13/12 10:00 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I was always told to start a fresh 727 in neutral, then go into forward, then reverse. A 727 doesn't actually pump in Park. That's why it says to check level in neutral. Anybody that does a 727 rebuild, knows how to pressure check everything before they put the valve body in. The valve body itself, or casing could of cracked from being over tq'ed. Or it could of been warped and not setting flat if tightend wrong. A valve sticking in the VB or things of the sort. I would of thought one of the pro's would have chimed in for you by now. The wrong type of seal will also cause havock. I am just a novice, but 40 yrs playing with mopars and watching friends build them has been a plus. Seen lots of times a 50 cent o ring will stop it dead
Re: 727 question for trans specialists.. [Re: Mopar-Al] #1334788
11/13/12 10:54 PM
11/13/12 10:54 PM
Ambridge, Pa.
Ambridge, Pa.
if the engine is running, the trans pump is pumping.
Re: 727 question for trans specialists.. [Re: rickraw] #1334789
11/13/12 11:28 PM
11/13/12 11:28 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
im pretty sure it doesnt circulate in park. A chevy does, but a 727 doesn't. It may be pumping, but to somewhere, the level will not drop. It is the same in park as with the engine turned off. It will read over full.
Re: 727 question for trans specialists.. [Re: rickraw] #1334790
11/13/12 11:32 PM
11/13/12 11:32 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
if the valve body was not oiled and the unit sat a yearthe pressure regulator valve could be stuck .if it is stuck open you will not have line pressure or converter charge.a little piece of metal etc could stick the valve.hope this helps.
Re: 727 question for trans specialists.. [Re: B1Johnny] #1334791
11/13/12 11:55 PM
11/13/12 11:55 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
We got the trans back from the shop today.. The owner told me he could not find anything wrong and he said he checked everything real close..
The one thing we both noted is the Red Line synthetic trans fluid we used turned from a strawberry soda look... into a cloudy milky strawberry soda..
I figured the oil probably aerated and it was actually foamy.. but I guess thats not the case.. The trans guy said thats common when water is introduced, but there is no way water can get into the trans as it has a separate trans cooler..
Anyways, we're putting the trans in tomorrow and we'll see what we'll see..
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334792
11/13/12 11:56 PM
11/13/12 11:56 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks again for everyone that has offered help
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334793
11/14/12 09:38 AM
11/14/12 09:38 AM
Start the car in park first and then go right to nuetral, then go through all the gears and back to reverse and wait for the transmission to kick into gear. Make sure your level is right at the add 1 pint line when running cold.
I had the same problem and found the o ring on the filter was not seated correctly on the valvebody causing the transmission to suck air.Make sure you got enough fluid.
Your fluid should not look milky unless he used the wrong band on your drum.
Re: 727 question for trans specialists.. #1334794
11/14/12 12:28 PM
11/14/12 12:28 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
How would using the wrong band cause the fluid to turn milky? and what is the right band?
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334795
11/14/12 06:49 PM
11/14/12 06:49 PM
Ambridge, Pa.
Ambridge, Pa.
never heard of that one. the only way fluid will look milky is water intrusion or a cooler failure.
Re: 727 question for trans specialists.. [Re: rickraw] #1334796
11/14/12 10:16 PM
11/14/12 10:16 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Update... We installed the trans today and this time the fluid pumped properly and the back tires went round and round...
We didnt check the color of the fluid this time around, we will this weekend, but the new motor install is just about ready to call "Finished".. Its now time to go racin..
Thanks again for everyone's help
Re: 727 question for trans specialists.. [Re: Jeepmon] #1334797
11/14/12 10:24 PM
11/14/12 10:24 PM
Ambridge, Pa.
Ambridge, Pa.
what was the problem?
